Old 11-20-2009, 12:11 PM
andrefranc andrefranc is offline
VK Member
High voltage caps.
I have an old TV with some caps rated 6,000 volts and if I need to replace them could I put 3 .003 mfd @ 1600v in series to replace a .001 @ 6,000v?
Old 11-20-2009, 04:03 PM
sean's Avatar
sean sean is offline
If you put 3 0.003uF 1600V capacitors in series you would get 0.001uF of capacitance with an effective voltage rating of 4800V. You would want to use 3 capacitors of at least 2000V rating. If you put 4 of these in series you would get 0.00075uF at 6400V. You can buy 6000V rated 0.001uF caps through Allied Electronics (part number 225-6015) and other vendors. These are made by ASC.
Sean - WØKPX
Old 11-20-2009, 07:16 PM
VK Member
Caps
I tried Allied for this cap and they told me minimum order was 97 of them and leed time was 13 weeks.
I know I figured wrong on the voltage. Would need 4 at .004 mfd I think.
Old 11-20-2009, 08:27 PM
Justradios at http://www.justradios.com/ has these for a few bucks each, I think the 8000 volt ones are actually a little cheaper and are still smaller than the originals.
I wonder when Allied went to the minimum order deal, I've bought from them before and there was no such thing then, but that's been a few years.
Old 11-20-2009, 09:50 PM
That doesn't sound right. I bought small numbers of caps from Allied twice in the last month or two. Don't remember the totals offhand, but it was maybe $20 for one order, $30 something for the other . . . nothing outrageous, or I would have tried somewhere else.
Old 11-21-2009, 09:13 AM
sean's Avatar
Allied's website says there are 30 in stock at $4.12 each.
Allied 225-6015
Sean - WØKPX
Old 11-22-2009, 01:13 AM
It's the 8KV ones that have a minimum quantity of 91. They're only $1.68.
http://www.alliedelec.com/search/pro...px?SKU=2256020
Old 11-25-2009, 06:24 AM
VK Member
Caps.
Thanks to all and I ordered some caps. from JustRadios.
