Old 12-04-2009, 10:10 PM
Motorola 9T1 scored
I've had mixed luck with buying TVs from ebay, but I couldn't resist gambling on this set. Some of you may have seen it listed a couple weeks ago. It had some visible damage to the cabinet in the listing - the whole left side of the CRT bezel is gone. Of course, all the knobs are missing too.
Only two other bid on it during the auction and they both retracted their bids. Probably when they noticed the damage. So I got it for next to nothing.
The seller had never shipped a TV before. Did it survive ? More or less. There were only two screws securing the chassis in the rear and they blew out the bakelite. Also, there's a crack running down one entire side.
At least it's mostly on the bottom and can't be seen. Finally, the HV cover is missing and the HV tube was thrown from it's socket!
Broken bezel, missing knobs, original speaker cloth. I think I'll try leadlike's J.B. Weld cast technique to fabricate a replacement for that missing segment of bezel.
This set has a glass faceplate with a few scratches. The foam gasket is intact.
The bakelite is incredibly dull and faded except where something protected some of the top. I've been doing a little experimenting with Brasso and Novus. I can already tell it's going to take a lot of elbow grease, but I think I can bring it back.
Sideview
Original, hinged back
Blown out screw holes
Crack running length of case
1B3 ejected
I salvaged all the broken bakelite bits from the box
The chassis is 100% original. All tube present and accounted for. I can't spot a single repair.
zenithfan1 has already agreed to send me a cover to replace the missing one
Even the HV caps are the original Motorolas like a time capsule. Almost makes me not want to restore it and toss all those Motorola labeled parts.
Finally, the picture tube is really bright!
Old 12-05-2009, 01:05 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
"Don't walk into the lighhhht!"
Is your chassis copper plated like this one? If not, I wonder why they wouldn't all be the same?
Also, do you have this label under yours? I wonder if they had to rework too many of them when mine was made.
Old 12-05-2009, 01:16 PM
LOL. I have that CRT hooked up to a 7VT2 set designed to use a 7JP4. The grid bias may be off a little.
Nope, not copper plated. Neither is my other TS-18 chassis. My 3 TS-4X chassis are though. I wonder if they decided it wasn't worth the extra expense?
Yes, I do have that label though I hadn't noticed it before.
I bet you're right - too many mistakes were being made.
Old 01-09-2010, 07:55 PM
Thanks to zenithfan1 and tvdude1 I now have a HV cover and a full set of knobs
The bakelite is coming along nicely
First, wet sanding #600- #3,000. Then, Novus #2 and Simichrome metal polish. Finally, Meguirs Tech wax.
Now to fill in the recesses with gold paint and repair that damaged front
Old 01-09-2010, 08:34 PM
Lookin' good Bob!
Old 01-09-2010, 08:45 PM
Charlie's Avatar
Charlie Charlie is offline
On Land
Wow... that Bakelite came out pretty good... I didn't think there was much hope for Bakelite once it looses it's shine.
Charlie Trahan
Old 01-09-2010, 09:29 PM
Now how to repair that damaged front
In a few years, we might be able to PRINT a matching section on our own desktop 3D printers... one model is already under $15K !
http://www.popularmechanics.com/auto...e/4320759.html
But for now, can you make a decent mold from the opposite side and cast a part?
Old 01-09-2010, 10:24 PM
Yeah, that'd be really sweet!
I suppose I will try molding the opposite side. I don't have any molding compound on hand though and I don't think playdough + jb weld will work on something this big
Old 06-24-2010, 12:58 AM
pugs5061 offered to lend me his cabinet to make a mold of the screen bezel. However, I've never done anything like this before. Any ideas ?
Old 06-24-2010, 12:50 PM
jeyurkon's Avatar
Do you want to do the whole front section, the round bezel area, or just the missing section?
Old 06-24-2010, 01:26 PM
Just the missing section. I'll try to color match it with paint and glue it in place. I bet with the right moulding bit a replacement could be made from wood.
Old 06-24-2010, 02:06 PM
jeyurkon's Avatar
That would probably work if you have a compass for your router.
You could also try a silicone putty to make a mold. Smoothon has tutorials on their site on how to do it. I'd recommend Equinox 40.
http://www.smooth-on.com/Silicone-Ru...133/index.html
Old 05-16-2012, 02:10 PM
Thanks to a tip from 'charokeeroad', I just scored an undamaged 9T1 cabinet
The grille cloth is somewhat different, but otherwise they're identical.
He sent along the chassis too, but it's kinda nasty. Should be good for spare parts though.
Old 05-18-2012, 10:06 PM
charokeeroad's Avatar
charokeeroad charokeeroad is offline
John Q
Glad to see the seller came through for you. One if my favorite set!
