Old 12-11-2009, 06:44 PM
Speaking of 30" Dumonts
Anyone seen one of these?
http://blog.modernmechanix.com/2007/...ross-the-room/
Old 12-11-2009, 07:59 PM
I wish. Looks like Allen DuMont at the control panel.
Phil
Old 12-11-2009, 08:20 PM
Same here. What an amazing picture.
Old 12-11-2009, 08:32 PM
nasadowsk's Avatar
Damn does run fast…
Must have been a prototype.
How heavy is the 30 inch tube? Being a metal/glass, I can't imagine it's that bad...
Old 12-11-2009, 09:10 PM
Tom_Ryan's Avatar
Tom_Ryan Tom_Ryan is offline
The facepate alone could easily have weighed over 100 lbs.
Old 12-11-2009, 09:38 PM
Just a guess here, but most faceplates on metal CRTs were quite thin, because they were strengthened by being placed in very strong compression as the metal to glass seal cooled. I suspect that the glass is not much more than 1/4-3/8" thick.
Update: I just crawled into my attic and weighed a 22" metal cone DuMont radar tube (P-7 phosphor) and it was only 33 pounds. a 16AP4 metal cone CRT is only about 11-12 pounds.
Old 12-11-2009, 09:55 PM
M3-SRT8's Avatar
M3-SRT8 M3-SRT8 is offline
The 30BP4 has a @ 3/8" thick faceplate. It's not too heavy.
I know...I got one.
Old 12-11-2009, 11:59 PM
cbenham's Avatar
cbenham cbenham is offline
[QUOTE=Eric H;2961767]Anyone seen one of these?
Not one but two when I was a kid. There was a DuMont dealer on a busy street in St. Petersburg, Fl. where I grew up. They had the 30 inch set in the picture and also a two piece version that had a remote control console on a huge umbilical cable so the CRT cabinet could be placed up high in a bar and the controls in a more convenient place to be operated. I dragged my dad down to their store and got a demo!
Old 12-12-2009, 06:05 AM
They prolly thought a 30" TV was a Miracle of the Age then...
Old 12-12-2009, 11:14 AM
kx250rider's Avatar
REAL TVs have TUBES!
Amazingly, the tube isn't heavy at all! The face is fairly thin glass, and the metal cone is also very thin. The reason they were able to do that is that te convex shape allows for plenty of strength, unlike the bigger flat Trinitron WEGA tubes which weigh 100s of pounds due to thick glass. The chassis on the Gen I DuMont Royal Sovereign is ridiculously heavy, but the Gen II is a smaller single chassis with click tuner, and isn't too heavy. I've moved the Gen II by myself, including lifting it into the pickup. The Gen I is a ball-buster though.
Only a couple of years ago, I finally got around to pulling the tube out of (formerly) my Royal Sovereign, which is recapped and working well. It had been in my fire in '88, and the soot had gotten between the tube and the safety glass. The glass for some dumb reason is installed from the inside of the cabinet, thus the tube must come out to clean it. It was a big job due to fear of death, or worse yet harming the possibly only excellent 30BP4 around, but I did it. The present owner was just as nervous; couldn't even stand to watch.
Here's a pic of the Gen I set, showing how shallow the 30BP4 is. (photo circa 1995). I got that set from a garage sale, and found out that it belonged to actress Jeanette McDonald. That set, after I cleaned it up (bad tube), is in the same collection today as the Gen II set.
Charles
Old 12-12-2009, 08:46 PM
Tom_Ryan's Avatar
While it may not have been that heavy, it's interesting that the screen diameter was actually 28 1/4 in. The mounting flange brought it out to 30 1/8 in. I suppose if Dumont hand extended the flange 7/8 in. we'd be calling this a 31" tube!
Old 12-12-2009, 08:54 PM
Old 12-12-2009, 10:01 PM
I wonder if Sony (or somebody) ever thought about making a metal-cone crt in later years? Too much to engineer?
Old 12-12-2009, 10:23 PM
M3-SRT8's Avatar
I'm just about to embark on resusitating an early production RA-119 Royal Sovereign. Just acquired an NOS Raytheon 27RP4A CRT, which I will install as a substitute for the origional, and quite dead, 30BP4.
Have to fabricate a new mask for it, which should be a minor challenge.
At least it's an aluminized 27BP4A. The resulting picture should be pretty good.
LJB
Old 12-13-2009, 07:33 AM
Dammitt, I wish I could find my "CRT" book...It told all about the 30BP4...From what I remember, they started having problems w/them right off the bat, due to lack of aluminisation, inadequate getters, etc. There were 2 builds of 'em, not very many on either one, & after the 2nd run ran out, DuMont offered to retrofit the puny little 27" tubes, complete w/a new mask, etc. Apparently, these were Muy Expensivo sets, & the owners raised Heck about 'em, so DuMont felt obligated to try & fix the problem. The book showed a picture of a workman setting the "cone" in a jig, prior to attaching the faceplate/screen. Looked like it must have been a fairly difficult/unwieldy process, the guy had to wrestle the fragile tube by himself, the whole business looked like it would have been like trying to manhandle a large, oddly-shaped washtub. I wonder what the scrappage rate was on these beasts...
