Old 12-15-2009, 06:01 AM
andrefranc andrefranc is offline
VK Member
Pix tube brightners
I have a brightner but doesn't fit on my old pix tube socket. Can I wire it in somehow?
Old 12-15-2009, 11:46 AM
You would need a new socket and plug, and then compare basing diagrams to make it work. Should be doable. But...brightners are plentiful. Unless the crt you are working on is something odd, I would just find a correct one. I have spares for the common types.
Another option-you could hard wire what you have, cutting the wires that run to the socket and splicing it in there.
Old 12-15-2009, 05:09 PM
VK Member
Brightner
I thought all a brightner did was step up via a transformer the voltage to the filament of the pix tube. Anyway it's a 7JP4 tube.
Old 12-16-2009, 01:21 AM
jpdylon's Avatar
jpdylon jpdylon is offline
<-- sucker for old sets.
Be careful with the brightners on the electrostatic sets. You can run into complications with motorola series string sets with the ballast tube regulators. If the CRT is dim, there is not too much you can do. I have had tremendously good luck giving the 7JP4 a good rejuvenation session of a beltron CRT machine - however there still has to be some cathode material left to rejuvenate. If someone has already attempted to rejuvenate the tube with an 'atomic blast" CRT rejuvenator it may be a hopeless cause.
Jordan
