Old 12-24-2009, 06:47 PM
painkiller64 painkiller64 is offline
Question about crts in a RCA Projection TV ppr475t (Chassies model-Hitachi VP6X)
Hi, I have this projection tv im cleaning up and well I was looking at each crt inside it (blue,green,red) and I noticed that there is a dirty rectangle stained in the middle of each individual crt. Well I thought that maybe it was the growth in the coolant so i cracked one open, drained the coolant out, wiped down the crt and its still there. Im thinking this is image burn-in but why would it be shaped and colored like that?
Any info would be nice
Thanks, Wes
Old 12-24-2009, 07:15 PM
N9ZQA's Avatar
N9ZQA N9ZQA is offline
VK Member
Wes -
That's just burn-in from the raster displayed on the CRT. The tubes in a projection set get driven harder than a direct-view set in order to get an image through the optics. That tube looks like it's got a few hours on it.
Somewhere there is a web page that shows burn-in patterns of projection CRTs at various levels of use. If the set showed a decent picture before, it shouldn't be too hard to get the same performance again, especially with fresh coolant.
-Jim
Old 12-24-2009, 07:26 PM
Thanks for the info Jim, that was exactly what I was looking for. It had a pretty descent picture before... a tad of greenish tint to it but overall pretty good for 20 some years old and free =P .
Hopefully some new coolant should make it look a little better.
1 more question though, that coolant that mcm still sells http://www.mcmelectronics.com/produc...LAID=220229728 , is that ok to use?
Old 12-24-2009, 07:52 PM
So, is it fairly common that the long axis of the raster is placed on the short axis of the tube in these sets? The burn pattern is rotated 90 degrees from what I would expect.
