Old 12-27-2009, 06:08 PM
ferninando ferninando is offline
chrome on plastic knobs?
Has anyone restored the chrome on plastic knobs? How'd ya do it?
Old 12-27-2009, 06:13 PM
Sam Cogley's Avatar
Sam Cogley Sam Cogley is offline
The Devil Inside
Search Google for "vacuum metalizing." There are some places that re-do that chrome.
Growing up leads to growing old and then to dying,
And dying to me dont sound like all that much fun...
-John Mellencamp
Old 12-27-2009, 06:55 PM
I mean do it yourself. not pay for it. Not for 100pt show restoration.
I can live with it if it can't be done.
Old 12-27-2009, 07:06 PM
I use a can of "chrome" spray paint from a local auto parts store... not 100 point quality for sure... but ok.
Old 12-28-2009, 12:48 AM
Thanks for that.
Old 12-28-2009, 12:57 AM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
The chrome paint used for plastic models doesn't look too bad.
Then there's this method.
http://www.caswellplating.com/pickak...ticchrome3.htm
Old 12-28-2009, 09:10 PM
amptramp's Avatar
amptramp amptramp is offline
VK Member
If I'm not mistaken, chrome plating on plastic usually starts with electroless nickle plating followed by chrome plating. Electroless nickle is a process that does not depend on external electricity and can be used on any surface - you could plate an apple if you wanted to. Then the nickle surface is used as an electrode for electroplating of chromium.
Old 12-28-2009, 10:17 PM
jeyurkon's Avatar
That might be possible. Electroless nickel has improved over the years. Orginally the surface of plastic had to be activated by dipping it in a dilute acidified stannous chloride solution. Then it would be dipped in an electroless copper solution. Once that thin layer formed a thicker bright eletrolytic copper plating was done. Then depending on how bright it was they would either go directly to chrome plating it or polishing the copper first.
