Old 04-21-2010, 10:26 PM
Sam Cogley's Avatar
Sam Cogley Sam Cogley is offline
The Devil Inside
Weekend pickups!
Got these at an auction this weekend. Grand total, $17.50. I spent another $15 just on an Atwater-Kent horn with no driver (not pictured).
GE J-83 (built by RCA). It has a bit of veneer damage on one side and some scratches, but is in overall nice shape. The white wire coming out of the middle has a factory-installed tag that says "Ground" - does anyone know what the black wire next to it is for?
Electrope. I have no idea who made this. The antenna coil is just laying loose on the chassis. The tuning capacitor is currently frozen, that will take a bit of work to fix. I have the other knob, but it's currently sitting on my dining-room table. Anyone know anything about it?
The tube sockets are all marked for Cunningham CX-xxx series tubes, but it has the old two-digit globe types installed.
Utah speaker, might be an A-100? Copper-oxide rectifier for the field coil wiring. Do they go bad like selenium rectifiers?
Anyone know where I could find an Atwater-Kent driver with no horn or a cone for the Utah?
Growing up leads to growing old and then to dying,
And dying to me dont sound like all that much fun...
-John Mellencamp
Old 04-22-2010, 01:08 AM
Wow, you got some good deals Lots of nice old globe tubes.
The red paint on the GE is wild.
Sorry, never heard of Electrope. Looks like quite a challenge to bring it back to life.
I suppose you could repair that Utah cone like I did for my WR8. Until you find the proper cone anyway.
Old 04-22-2010, 02:17 AM
AUdubon5425's Avatar
Great deal. If you decide to tackle that Electrope you might have the last one left!
Old 04-22-2010, 08:23 AM
Reece's Avatar
Reece Reece is offline
That Utah is a fine example of an early big honkin' electrodynamic speaker and it ought to be restored. I believe the copper oxide rectifiers are pretty reliable. First order of business would be to determine if the field coil and the voice coil are OK and not shorted or open, and that the voice coil is not rubbing on the pole piece. You could send it to Hank Brazeal for a professional reconing:
(205) 403 6243, E-mail [email protected]
Or you could try to recone it yourself with one from Mat Electronics.
http://matelectronics.com/acatalog/M...ories_208.html
Don't know if the cones they have would have the same depth as the Utah's. Might take some cutting and fitting. What some have done is to use a piece of the new cone to repair the old, or cut the old cone out except for an inch or so around the voice coil and then cut and fit the new cone to glue there.
BTW I don't think the red paint inside the G.E. was original!
Reece
Old 04-22-2010, 08:49 AM
Sam Cogley's Avatar
The Devil Inside
I was actually thinking about your cone repair as inspiration. This one is far less gone than yours was.
It's actually a little tiny electrodynamic speaker - the cone is only about 8". I've found a webpage about an identical speaker that came in a wooden cabinet. The only difference there is that the oval "Utah" decal was located on the wooden cabinet and not the chassis.
Good news on the rectifier. I'll check the coils with a multimeter sometime this weekend, I've already checked the voice coil for rubs and found none.
Some good options. Thanks!
If it isn't, someone went to a lot of trouble. It looks like it's under riveted terminal strips.
-John Mellencamp
Old 04-22-2010, 10:53 AM
Reece's Avatar
Red paint: well that's a new one on me!
Speaker size: so not so big, but some of the first ones, like in the RCA RE line of sets, early ED speakers, were only about 9" or so IIRC, but sounded so good and so loud compared to what was available before (horn speakers and pin-drive cones) that the sets sold like hotcakes, in spite of their price.
Reece
Old 04-22-2010, 01:04 PM
PunkTiger's Avatar
PunkTiger PunkTiger is offline
SW DXing
Re the J-83's black wire: perhaps it's for the antenna. I don't see any other antenna connections on the back.
Even though the red paint was an attention getter, what I found really nifty about that set was the indentation in the left side of the case to make room for the globe tubes. It's those little details I find fascinating.
Old 04-22-2010, 01:10 PM
Originally Posted by PunkTiger View Post
...Even though the red paint was an attention getter, what I found really nifty about that set was the indentation in the left side of the case to make room for the globe tubes. It's those little details I find fascinating.
I hadn't noticed that - I like those little details too. Nice patch of asbestos as well!
Old 04-23-2010, 02:47 PM
Reece's Avatar
I'll bet that indentation was a way of fixing an "oops!" when they hadn't allwed for the tube dimension but the cabinets were already made.
Reece
Old 04-23-2010, 06:12 PM
Bob E.'s Avatar
Bob E. Bob E. is offline
VK Member
With the exception of that large coil and small transformer in the front-left corner of the cabinet, that "Electrope" looks exactly like my Apex model 36 Neutrodyne set. Maybe yours is a short-wave version of that. I will try to post pictures later.
--Bob
Old 04-23-2010, 10:19 PM
Sam Cogley's Avatar
The Devil Inside
--Bob
I looked up a picture of an Apex 36. You're right about it being identical except for the bezel on the tuning window and the extra transformer. The coil is just sitting there loose, it probably has nothing to do with the radio. Mine has what looks like a power outlet on the chassis next to the power transformer, I'm assuming it's there to power up an electrodynamic speaker.
-John Mellencamp
Old 04-25-2010, 08:34 PM
Sam Cogley's Avatar
The Devil Inside
Both coils on the Utah are OK, but all of the wiring is somewhere beyond shot. I'm going to have to take the bell off of the transformer to run new wires inside of it.
That extra transformer on the Electrope/Apex is attached firmly and has wires running under the chassis. I still haven't pulled the chassis out of the box.
-John Mellencamp
Old 04-25-2010, 09:25 PM
Bob E.'s Avatar
VK Member
It's not visible in your picture (the large coil is obscuring it), but there is a long hump in the chassis that accommodates a couple of AF transformers underneath. Probably one burnt out, and the replacement was put above-board, since it had mounting feet in that orientation.
These radios pre-dated electrodynamic speakers, there should be a pair of jacks off near the left side of the chassis (again, underneath that large unrelated coil). You could plug in headphones or a horn speaker, or a pin-drive cone speaker. I have a nice Rola-cone that I will use with mine, once I repair it (broken drive pin).
FYI, the schematic is available at Nostalgia-Air, but it's under the "US Radio and Television" heading (which is what Apex became shortly after this model).
--Bob
Old 04-25-2010, 10:21 PM
Sam Cogley's Avatar
The Devil Inside
The large hump is there, as well as the speaker jacks. The data plate I've seen in other Apex 36 photos isn't. Would it work with a self-energized electrodynamic speaker? Any idea what that AC socket is for? Also, do you have any suggestions on freeing up the rusted gear mechanism in the tuning system? I don't want to mess up the varicap.
-John Mellencamp
Old 04-26-2010, 12:08 AM
Bob E.'s Avatar
VK Member
Ooh, I didn't think of a self-energized electrodynamic...I suppose if the impedance is in the ball-park you'd be good to go. Perhaps, as you theorized earlier, that is what the AC Socket was added for.
By the way, it's cool that yours has all "S" envelope tubes. Mine had a full set of Philco "S" envelope tubes (with paper stickers) except for the 227 detector. I found an RCA globe 227 in my stash of tubes so it would have a complete lineup. Mine had already been restored by the previous owner (RIP, it was from an estate sale), but I pulled all the tubes out for cleaning and testing, before reading about Neutrodyne sets and that the tubes were "neutralized" for their particular sockets. I need to re-neutralize it now, as it howls terribly at one end of the dial. I've made a neutralizing tube-socket adapter, just need to sit in front of it and do some methodical twiddling.
As for the rusted tuner, I would just be dribbling a couple drops of Liquid Wrench on the shaft where it goes through the frame, probably several times over the course of several days. Let it soak in. Be patient and gentle, I think it should be able to be freed up with penetrating oil and care. At least we are not dealing with pot-metal! Oh, and mine has a sheet-metal panel for a shield between the rectifier and the rest of the tubes. I'm still looking on various computers for those pictures I took...
One thing I notice about yours that is different is that it has frequency markings on the dial. Mine just has the typical 1 - 100 logging numbers. That has to be an early implementation of that type of nomenclature...I wonder if it was a retrofit?
Any way, have fun, this particular type of radio was only around on the market for a couple of years, things were changing so fast.
--Bob
