Old 04-22-2010, 07:23 PM
A Philco from New Zealand
Just bought this off the Australian eBay, and I'm using mellowtoneinn's pictures (pretty good ones) from that auction, as it's just been shipped.
A closeup of the dial: Stationized, like Australian radios.
and the inside back:
It's a 4 tube radio, don't know which tubes yet. Circa 1953. Though that output transformer looks too new. Maybe a replacement.
Looks similar to this one, the PHILCO BAKELITE 1956 5 V ALABAMA sold in Australia:
And the innards look quite similar, as you'd expect:
Other than the 3rd knob under the dial, and differing dial,
Old 04-22-2010, 07:47 PM
Kewl ! Are those guys 220 VAC ?
Old 04-23-2010, 01:21 AM
Pretty sure that they are, and it seems all such radios used power transformers. 220VAC is a lot less forgiving than 120V, not that 120 doesn't deserve respect. After restoration, there's 240@60Hz waiting for this radio:
a power plug fed 240VAC (pair of 120VAC's) at my place. Turns out these old American crawfoot pattern outlets are the exact same shape and pattern as NZ and Aussie outlets.
The voltage being 10% higher shouldn't be much of an issue for the power transformer, as, for the same size transformer, it needs 5/6 as many turns on 60Hz vs 50Hz. So that 220V@50Hz transformer can accept up to 264V@60Hz. However, the filter cap voltage and heaters and so on may get a little too high, so a little extra series resistance may be needed.
Old 04-23-2010, 06:09 PM
Hemingray's Avatar
Hemingray Hemingray is offline
Vintage Geek
There's a few hardware stores here that STILL sell the single version of those outlets.
Death: Man how old is this TV?, You probably get the DuMont network on this thing!
