Old 05-18-2010, 02:20 PM
Sam Cogley's Avatar
Sam Cogley Sam Cogley is offline
The Devil Inside
Picked up a few more radios
Methinks some of the ones I have are going to have to go...
Found a garage sale today with two interesting radios - A Fisher 100 FM Microceiver and a Zenith X390 clock radio with a 7N06 chassis. The Fisher is an odd design with five separate FM tuning dials and knobs - each knob is also a pushbutton, it allows you to preset five stations and tune between them at a button push. The Zenith is only the second AM/FM tube clock radio I've run across, the other was also a Zenith but utterly trashed. Picked them up for $5 each.
The Zenith looks just like this one: http://radio.mcdougallshome.net/old-...istance-radio/
Growing up leads to growing old and then to dying,
And dying to me dont sound like all that much fun...
-John Mellencamp
Old 05-20-2010, 06:08 PM
Fisherdude's Avatar
Fisherdude Fisherdude is offline
The Golden Age of Hi-Fi
Sam, if that Fisher 100 works, you're going to be amazed by the sound. I have one as my main "bathroom" radio, and two more for parts/repair. There was also a second speaker as an option. I've seen exactly one of those speakers in the last eight years.
I may be growing older, but I refuse to grow up.
Old 05-20-2010, 06:37 PM
That Zenith is a '67 ("x" in model number) that uses a '66 designed ("N" in chassis number) chassis. Zenith made tube radios as late as '69.
Not bad at all for $5/each.
Old 05-20-2010, 10:27 PM
Sam Cogley's Avatar
The Devil Inside
Interesting. The tube layout chart on the Zenith is dated 1959. I haven't fired it up yet, I'll give it a full rehab.
The Fisher works fine (except for the AFC, which makes the signal worse). Great sound for a little box. It has a bit of damage on one cabinet edge, the AFC knob has a broken spot (I'll fill it in with some epoxy, shape and repaint), and two of the brights are missing off of the larger knobs. It had a cable for the extension speaker, but the speaker itself was nowhere to be found - I even asked the seller. I might do a complete cabinet rebuild with real walnut veneer - I have JVC/Delmonico AM/FM MPX table radio in the garage that needs the same treatment.
If the Zenith is indeed from '69, it's rather humorous that the (presumably) more expensive Fisher from the same era has vinyl "veneer" while the Zenith has real walnut.
-John Mellencamp
Old 05-21-2010, 12:18 AM
Actually, your Zenith is from '67 ("x" model line); but, Zenith made a tube radio as late as '69 ("z" model line). Unlike many other manufacturers, Zenith made some quality "last gasp" tube radios.
Old 05-23-2010, 04:47 PM
Sam Cogley's Avatar
The Devil Inside
Anyone know how to get into the Fisher 100? I pulled the three screws on the back but nothing happened.
-John Mellencamp
Old 06-03-2010, 09:11 AM
Fisherdude's Avatar
Hey, Sam!
Sorry it took me so long to check back into this thread. Kind of embarrassing to admit, especially since I used to help mod this forum, but I rarely come back over here anymore.
There are four screws, three on the back and one on the bottom. Take out the one on the bottom and the chassis should push right out the front.
I'm assuming you already figured that out, though!
Old 06-03-2010, 10:07 AM
its been a while bit IIRC i had a allied 333 that did the same thing, AFC made it worse, I think its how the discriminator coil is adj. the AFC looks to adj the LO until there is null at the output of the discrimator indicating its tuned to the IF frequency. If the discriminator is not set right this null take place somewhere above or below the IF frequency.
I think I was able to make minor tweaks in the secondary of the discriminator until switching from AFC to non AFC did not effect the signal strengh or sound when the non afc is tuned perfectly. Of course any time messing with IF you need to be sure which side you are adj the afc line secondary should swing from pos to neg quickly when adjusting the secondary of the discriminator.
again its been a while....
Old 06-03-2010, 01:31 PM
Sam Cogley's Avatar
The Devil Inside
Hey, Sam!
Actually, I hadn't. I've hauled the 100 outside to listen to baseball several times, but haven't done any work on it. Do you notice that the volume on yours wobbles around with signal strength?
-John Mellencamp
Old 06-03-2010, 11:14 PM
Fisherdude's Avatar
No, it's quite steady.
Old 06-04-2010, 12:36 AM
Sam Cogley's Avatar
The Devil Inside
Obviously mine needs some work...
-John Mellencamp
