Old 06-08-2010, 10:21 PM
Motorla VK101M on the bay
I like how it used a whole bunch of the same knobs as the VT71s. The holes in the side seem odd. Are they for adjustments
http://cgi.ebay.com/1948-MOTOROLA-GO...-/160443264575
(no affiliation)
Old 06-08-2010, 10:23 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
I like the way the radio folds out.
Old 06-09-2010, 11:15 AM
That slot over the knobs almost looks like where the DVD's go...
Old 06-09-2010, 11:27 AM
RDusel RDusel is offline
Wow, that is a very cool set. Wish it was closer..
I like the "air suspension" speaker (ok, more like "Air cone"). I wonder what became of the cone? Eaten by insects perhaps?
And the two rectifiers right in the back with a heat deflector look neat. Bet that is good for a cold winters night.
What kind of rectifiers are they? An unusual brand of 5U4 or a commercial/military rectifier? The glass tube bulges out past the diameter of the base..
Rob
Old 06-09-2010, 12:35 PM
jeyurkon's Avatar
Rob
I think the glass bulging is an illusion. To me it looks like the glass is straight. The sockets seem to stick up fairly high under the base.
Old 06-09-2010, 01:40 PM
Assuming that's a TS-5 or TS-7 chassis, those are 5U4Gs.
Old 06-09-2010, 01:50 PM
I think I have seen radio/phono consoles with a tilt-out drawer for the turntable. Philco comes to mind.
It looks like the side holes have little caps that you pull out to reach the adjusters. I wonder how many of those caps ended up in people's boxes of mystery junk?
Phil
Old 06-09-2010, 02:12 PM
My guess is that the tubes have been replaced, a 5U4G IIRC, would have a "coke bottle" shape. These look like a fairly large diameter straight tubular envelope mounted on a "stepped diameter" base... I believe that I have seen "Military" 5U4s (or perhaps 5R4s) with this type of construction.
Old 06-09-2010, 03:49 PM
Steve K Steve K is offline
I have one of those sets in my collection. It is hard to see in the picture but the plastic thing above the knobs has the channel numbers in it. A light moves behind them as the channel knob is turned. The side holes are for the secondary adjustments. That set is missing a side knob that is used to adjust the vertical and horizontal holds. There was one knob to make those adjustments. You pulled it off one shaft and stuck it into the hole for the other adjustment. It seems odd but according to the Motorola manual there was just one knob.
Steve
Old 06-09-2010, 06:15 PM
pugs5061 pugs5061 is offline
No time for this hobby
Thats a beautiful set! I checked and Jordan MN. is North and West of Duluth. Absolutely georgeous country up there. Probably 12-14 hours from Chicago. Too far. Probably too far for even Minneapolis! My Mom is in Rhinelander WI and its too far. I hope there are some TV Buffs up there in the Northwoods.
The surefire way to make sure your CRT is dead, sell it to me!
Old 06-09-2010, 06:18 PM
I meant North and East of Duluth.
Old 06-09-2010, 06:58 PM
TheNixer's Avatar
TheNixer TheNixer is offline
That's awesome info Steve! I wondered myself what that was on the side of the TV.
Old 06-09-2010, 08:54 PM
Wonder whats in the hinged box directly below the 5U4's?
