Old 06-13-2010, 03:39 PM
EVBoy EVBoy is offline
Operadio
Has anyone heard of the brand Operadio?
Old 06-13-2010, 03:50 PM
capbuster capbuster is offline
VK Member
Yes . You can find schematics herehttp://www.nostalgiaair.org
Old 06-14-2010, 07:26 PM
VK Member
Here some infohttp://www.radiomuseum.org/dsp_detai...ompany_id=3000
Old 06-14-2010, 07:30 PM
VK Member
some reason did not post link right
Old 06-14-2010, 07:32 PM
VK Member
http://www.radiomuseum.org/dsp_herst...ompany_id=3000
Old 06-16-2010, 12:02 PM
Thanks for the links. Here is a photo. Some sort of old slide projector with a turntable. I think Operadio made just the phono amp.
Old 06-17-2010, 10:02 PM
Bob E.'s Avatar
Bob E. Bob E. is offline
VK Member
Well it says right on it what you've got...an Explainette! I have one somewhere, they were for traveling salesmen to make presentations in the days before Powerpoint (or computers, for that matter...). The cover for the unit has a small projection screen inside, or you could use a blank wall. I don't have any filmstrips or records for mine (they came as a set, when the soundtrack played a short tone, you advanced to the next image on the filmstrip). Here is one on eBay with a filmstrip, but no records:
http://cgi.ebay.com/Explainette-Phon...item4aa123ebf9
Operadio had been around since at least the 30's, they made audio components (speakers, amplifiers) on contract for lots of different manufacturers. I have a jukebox from 1933 that has Operadio speakers.
--Bob
Old 06-18-2010, 06:58 AM
Reece's Avatar
Reece Reece is offline
They also used filmstrip projectors in schools, along with a record played on any player they already had. As noted, at the tone you advanced to the next frame. The filmstrips were coils of 35mm B&W film, no reel required. You fed the coil in the top, I think, and it recoiled itself as it emerged frame by frame at the bottom.
Reece
