Old 06-14-2010, 02:27 PM
'56 RCA 8BT10K handwired transistor portable
Just got this one off of ebay, a '56 RCA 8BT10K 7 transistor AM radio. This one is built on a metal chassis with socketed transistors, which I especially like. It also uses an oddball battery that's a new one on me. The RCA battery number is VS301, which is a 9V battery pack with a 3V tap. Since this battery probably hasn't been made in 40 years, I'll have to make up something using modern batteries. One major problem is that the knobs are disintegrating and coming apart with missing pieces where they slide over the control shaft. One knob had already been glued back together and I had to glue the other knob. They are staying on the shafts; but, I don't think they'd take very much abuse. I connected the radio to two power supplies to get the -3 and -9 volts; and, it seems to play OK.
Old 06-14-2010, 02:53 PM
That guy looks like a Tooob set they just took the Tooobs out of & put them new-fangled TranSister thingamabobs in...
Old 06-15-2010, 08:32 PM
electroking's Avatar
a- v- karma member
But those TranSister things use holes instead of electrons! Well,
they use electrons too, but it's awfully complicated...
Old 06-16-2010, 03:49 PM
radiodayz's Avatar
radiodayz radiodayz is offline
radiodayz
Indeed, looks very similar to old RCA portable tube sets I've seen (in pictures).
The RCA Globe Trotters are supposed to be very good for long-distance AM reception. If anyone has or knows of one for sale (either kind), let me know.
I have one of those around here, somewhere
