Old 06-28-2010, 11:40 AM
National's Avatar
National National is offline
The BIG Entertainer
Question Head Differences...
Hi there,
I have an unusual question on heads - PAL vs NTSC, reason i ask is that ive seen a model of VCR that in PAL format specifies a different upper and lower cylinder than the NTSC version, upon query no one could tell me why - anyone know of the difference here? as far as i can tell all the angles are the same, are the gaps different / coils etc? i initially thought cylinder speed would have been the only difference.
Having said that, ive seen NTSC and PAL using same cylinders on lower models.
Old 06-28-2010, 10:26 PM
Originally Posted by National View Post
Hi there,
I know that different VCR speeds use different gaps (19 vs. 38 vs. 57 microns on USA NTSC VCRs, for example), so maybe that is part of it.
