Old 07-02-2010, 11:51 PM
danrulz98's Avatar
danrulz98 danrulz98 is offline
Interesting little GE
Found this on Ebay when trying to find an example of a Motorola set. Looks kinda interesting, seems to be in really good shape.
http://cgi.ebay.com/Vintage-GE-Mid-C...ht_7457wt_1137
Old 07-03-2010, 01:29 AM
Wow, it sure does have a nice finish!
Old 07-03-2010, 06:28 AM
I have one like that, easy to work on, prob shorted filter and blown internal fuse. IIRC I had a couple caps that need replacing but no big deal.
I reall killer without the back, hot chassis, relies on little plastic parts to isolate the metal chassis from the metal cabinet.
Old 07-03-2010, 06:30 AM
here is mine, different handle but pretty much the same. I like the color better than the yellow on mine.
Old 07-03-2010, 09:54 AM
I think this TV may be a GE, judging from the "GE" logo on the CRT base.
Old 07-03-2010, 01:12 PM
I find it interesting that the logos are missing on so many of these little GE sets. Some, however were branded "Hotpoint", but they were the same set.
On the little 9" version, GE made the front bezel out of plastic, and molded the logo into the plastic.
Both the 9" and 14" are desirable little portables for a collection.
Old 07-03-2010, 03:52 PM
electroking's Avatar
a- v- karma member
Well, it may indeed be a GE, but General Electric did supply OEM parts
(including picture tubes) to many manufacturers. The Canadian built
Electrohome in my avatar does have a factory GE CRT.
Old 07-03-2010, 05:44 PM
I think it's a GE, the Hotpoint I have says Hotpoint right on the handle, also the holes for the logo are much closer together than the GE.
The internals are made by GE in any case.
Old 07-03-2010, 06:28 PM
Good point! I forgot about the handle...I traded off the Hotpoint that I had many years ago.
I wonder if the color choices were the same...I don't think that I ever saw a Hotpoint in turquoise and white (mine was dark red and white or perhaps rust color and white), but nearly all GEs that I encountered were turquoise and white. Cute little sets!
Last edited by jr_tech; 07-03-2010 at 10:50 PM. Reason: add "and white" to clarify color scheme
Old 07-03-2010, 10:28 PM
OvenMaster's Avatar
DTV blows
I once had one exactly like that when I cleaned out my grandmother's apartment back in the early 70's, except it was orange-red and white. It was indeed a GE. After replacing a diode, the UHF tuner worked again. We used it for years.
Tom
Old 07-04-2010, 07:17 AM
Dennman6's Avatar
Dennman6 Dennman6 is offline
Dave I see you are a Twilight Zone fan. Your set is showing the great 1962 episode "Nothing in the Dark", with Dame Gladys Cooper as Wanda Dunn & Robert Redford as Mr. Death. Cooper was excellent in just about everything she did, & Bobby was as the start of his career in this. "Mother, give me your hand".
Another great Gladys Cooper episode is "Night Call", where she plays elderly invalid Elva Keene who starts getting phone calls from her long dead fiance after a storm pulls down telephone wires over a cemetery.
Dennis Forkel
"Take time to deliberate. But when the moment for action arrives, stop thinking and go in!"-Andrew Jackson
Old 07-05-2010, 04:36 PM
While we are still on the subject of the turquoise/white GE 14" set, I have a question about the color scheme on the little 9" version that I posted above.
The paint on the side panels does not match the front plastic piece very well, with the front plastic being more like "seafoam green" than turquoise. The paint inside the cabinet appears to be the same color as that on the outside, so there is no evidence that the outside paint has faded. Likewise, the knobs and front bezel appear to be fairly uniform in color, with only the slightest hint that the parts may have "yellowed" slightly in sunlight.
Any ideas... Bad factory match? Deliberate 3 color scheme? Chemical aging?
just curious,
Last edited by jr_tech; 07-05-2010 at 05:06 PM. Reason: Trying to get pix to show up
Old 07-05-2010, 05:32 PM
just curious,
I don't know the answer but mine is exactly the same way.
Since the front is the same color inside and out, even where the mounting post has broken off I've always believed it was supposed to be that way.
Old 07-07-2010, 08:53 AM
kvflyer kvflyer is offline
just curious,
I strongly suspect that the plastic color has shifted due to age. I am no chemist so I can't begin to describe exactly what has happened but I have seen the color of plastic change over the years. There would be no reason to have two different shades of "green" I would think.
Just my 2˘ though...
Old 07-11-2010, 03:07 PM
holmesuser01's Avatar
Its a GE for sure. The channel selector has the same design in the center that our 23" GE lowboy had. That would be 1956...
