http://cgi.ebay.com/RCA-TRANS-I-WANT...item255bf36135
I have no connection whatsoever with this auction, but it is a great record all about the promise of having a television in your home. RCA isn't mentioned specifically,but who cares ! You won't be disappointed ! Pallophotophone |
That's very cool, I placed a bid on it.
It says "Unpublished" "Cleared for broadcast" with none of the usual copyright info on the label. I wonder if that means it could be posted on YouTube without getting busted by the Copyright Police? |
Good Luck ! And I think you are right about not having to worry about copyright.
BTW, it's a 78 rpm and pressed in vinyl so if it hasn't been played to death on consumer gear, it will play beautifully! Pallophotophone |
It's approx. 1955. If you hadn't bid on it, I certainly would. Good luck. Bill Cahill
"Tubes are those little glass things that light up orange unless there is a short.. Then they light up all pretty colors..." Please join my forum. http://www.tuberadioforum.com/ |
