Here's one of my favorite record players. 1947 Newcomb. Two speed.
![]() Bill Cahill
"Tubes are those little glass things that light up orange unless there is a short.. Then they light up all pretty colors..." Please join my forum. http://www.tuberadioforum.com/ |
Nice! I have the mid-late '50's 4 speed version of this player. I'm sure these models from the '40's are hard to find today. One day, I hope to find one of these as well as one of the maroon R12 models.
I feel very lucky to have 5 of the Maroon R12 models. Two are from my grade school.
One is a late 4 speed in maroon, one is similar to school machines, and, I have an odd ball early one with a diamond shaped spkr cut out. Everything is mounted on rubber shocks. Bill Cahill
I think Newcomb made a variation of the R12 for many, many years. They made several maroon versions, followed by the newer models in grey or tan cases, then the RT12, which was a solid state version. I never really cared for the solid state newcomb's. They were decent performers; but, the amplifiers were much harder to work on than the tube amps. I used to have a late tube type newcomb model ED10 from the early '70's (?). It used a SE 6V6 amp and was housed in the newer beige case with the red and blue "N" badge. For a little 5 watt amp, it sounded really nice. A friend of mine, who has helped me out over the years, needed something to play 78's on and I gave him that record player. I don't know exactly when Newcomb stopped making tube record players; but, I used to have a '71 electronics master catalog that still had some tube models listed (both the transcription players and the smaller classroom models).
It just amazes me how many updates they made on their machines. Even the transcription players.
TR-16A 10 watt amp. Type transcription player. Case: Maroon. Single 12" spkr. in removable lid. 25' spkr. cord. Treble, bass, phono vol., and, mike vol. 2 mike jacks. uses GE magnetic cartridge. Mechanism: 2 spd. 78-33. Variable speed, but, no strobe. 10" turntable with fluff coating. Power on light on front panel of amp. R-12. First version I have. Maroon. 3 speed. Grey metal. Primitive tone arm hard mounted on a seperate panel, shock mounted. Motor mech. shock mounted. Spkr. shock mounted on rubber grommets, instead of springs. No springs in cabinet feet. Cut out for 6"X9" spkr. is diamond shaped. 5 watt amp. R-12 Similar to later ones. Maroon, but, still with primitive tone arm. 3 Wheel system with idler wheel. R-12 later version. My school's machines. Same drive system 3 speed. Improved amp. Trimmer, lighter tone arm. Last one. R-12. 4 speed. Maroon case. Improved amp. LIghter tone arm. Single idler wheel. TR-25. I have Two. One restored, other not finnished. On all three transcriptions interesting way of varying speed pitch. On earliest one, the TR-16, and, one of these, motor has a secondary winding wound in reverse that connects through two high wattage pots, to the 6 volt winding on power transformer. It actually slows motor down. The oneTR-25 with this motor is a 3 speed. 25 watt amp. Phono treble, phono bass, , phono vol., Mike 1 vol. Mike one bass, Mike 2 volume. Maroon top, maroon double spkrs, grey bottom. Maroon painted metal. Tone arm grey with adjustable weight for lp's, and, 45's. Lighted speed strobe. Other TR- 25. Basically the same except the following. 4 speed. Motor speed pitch is done by a permanent magnet between two steel brackets. An aluminum disc on motor shaft goes in middle. It works, but, since it works by magnetism, you get a strong ozone like smell out of it. They were doing alot in those days to try to put out a better product. These early machines were actually very good. I also know they offered an expensive set of speakers in the 50's that were 4 seperate speakers, and, they also offered a 3 way spkr. systme. Bill Cahill
| Audiokarma |
That player would have been a classic today.
Jeff, WB8NHV Collecting, restoring and enjoying vintage Zenith radios since 2002 Zenith. Gone, but not forgotten. |
I was sent an e mail yesterday that is views of some pages from catalogs from 1951, and, 1959.
I gleanned a few prices based on the somewhat confusing aray of improved models. Here is what I got. All original prices from '51. TR-16 179.99 Maroon case 2 speed Single semi permanent needle in GE magnetic cartridge. 10 watt TR-16C Maroon 3 spd. Maroon 10 watt 2 needle GE Magnetic cartridge 199.99 TR 16A Maroon 3 spd. 10 watt Crystal cartridge. 169.99 TR-25 AM 25 watt 3 Spd. Strobe turntable.Grey case, Maroon top, and, two maroon spkrs. 299.99 The TR-16's all had adjustable speed, but, no strobe. Bill Cahill
Be nice to see some scans of Newcomb literature. They made better than average school phonographs. I saw a early-middle 1970's Newcomb today in very nice condition for $59. I am likely going to buy it for 78 use. It does have tape outputs and pitch control and a fairly light arm for such phonos.
