Old 08-21-2010, 07:27 PM
VA561's Avatar
VA561 VA561 is offline
Runs great except............
I have a 1950 RCA 50T-1404. It runs great except that the picture is tilted down to the right as you are looking at the screen. I tried using the yoke adjustments but that only moves the screen up and down and left and right.
Any advice would be appreciated. You can see by the attached photo that the image is tilted down to the right.
Old 08-21-2010, 07:31 PM
Try rotating the yoke. There's usually a thumbscrew holding it in place.
Old 08-21-2010, 07:40 PM
You should be able to rotate the deflection yoke on the neck of the tube. Likely there is a wingnut that holds the yoke...check for a slot and wingnut at the top of the yoke assembly.... be careful! if it is a metal cone tube, your hand will be close to the HV, as you try to turn the yoke!
Old 08-21-2010, 07:55 PM
Model # 50-1404 sounds like a Philco number.If so, set uses a 12LP4 CRT. Dave.
Old 08-21-2010, 08:22 PM
If that is the case, the Yoke clamp is likely hidden behind the focus coil, as in this example in my grubby attic.
Old 08-21-2010, 08:27 PM
Adam's Avatar
Adam Adam is offline
Am I missing something here, or is that whole tv sitting on it's side? Look closely at the picture, the curved sides of the crt mask appear to be on the top and bottom.
Old 08-21-2010, 08:58 PM
Tom Albrecht's Avatar
Looks like the whole picture is rotated 90 degrees, which is not exactly helpful, but if you turn your head sideways (or imagine what it would look like if you did), you can see that the picture is then slightly downhill to the right.
Definitely needs the yoke rotated just a tad, which is different from the centering adjustments that have been tried.
Old 08-21-2010, 10:29 PM
VA561's Avatar
Sorry about the picture. Something didn't work when I tried to post it. I tried to post it so it was upright. Also I was mistaken, it is a PHILCO. That being said,
Where would the adjustment be to rotate the yoke?
Old 08-21-2010, 10:41 PM
VA561's Avatar
This is the correct angle.
Old 08-21-2010, 11:11 PM
In the picture that I posted above, a screw head / 5/16" hex head (may be 1/4" on some models) screw tensions the metal clamp around the yoke. Reaching in from the back of the set, it should be in about the 11:00 position, near the left strut that comes from the front of the set, hidden by the flange of the focus coil...loosen it and you should be able to turn the yoke.
Loosen tension bolt on yoke clamp ... Pix 1
Reach around focus flange and turn yoke body... Pix 2
Old 08-22-2010, 06:03 PM
VA561's Avatar
Thanks everyone for the info. I was able to adjust the yoke and correct the picture tilt. Thanks Again
