Old 08-28-2010, 10:42 AM
electronjohn's Avatar
I like....big sparks!!
Lightning protection
I'm pulling down my G5RV and converting it to a ladderline-fed dipole. Problem is...can't find any lightning protection device for 450 ohm ladderline. The G5RV used a ladderline matching section connected to coax, so it was easy to put a lightning arrester inline with the coax, then a coax stub to the antenna tuner.
I've got a bunch of old 300 ohm twinlead arresters around...but the terminal spacing is too narrow to accomodate the ladderline. Would snipping out one of the "rungs", stripping, spreading apart slightly and then fastening to the arrester terminals work?
Old 09-01-2010, 11:04 AM
Reece's Avatar
Reece Reece is offline
Or, use two of your arresters, one for each line, no adapting the spread of the twinlead required.
Reece
Old 09-02-2010, 11:02 AM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
Take a look at an I.C.E. (Industrial Communication Engineers Ltd.) Model 309 or 309H lightning supressors. I have a 309H myself.
http://www.iceradioproducts.com/impulse1.html#m308
(no affiliation)
Old 09-03-2010, 01:30 PM
Hmmm...thanks for the suggestion, Reece! And, Ed...$46 seems to be mighty reasonable for that I.C.E. product. Thanks for the info!
