Old 09-06-2010, 12:56 AM
Philco with Beam of Light on craigslist
$20. I wonder if this is worth picking up for the beam of light phonograph
http://chicago.craigslist.org/nwc/atq/1937023404.html
File Type: jpg 3n23o83l75Y55V45U3a9416f2a87b732c1c8e.jpg (7.1 KB, 57 views)
File Type: jpg 3nf3k13o95O15Q15T2a94d169e024fc0f1dc0.jpg (8.4 KB, 38 views)
Old 09-06-2010, 03:24 AM
AUdubon5425's Avatar
Oh heck, I would. I don't know how much of a headache it would be to fix one of those, but when will you see another?
AUdubon5425 Youtube Channel
Old 09-06-2010, 07:11 AM
Reece's Avatar
Reece Reece is offline
Agree with AUdubon...tricky to get the pickup working, but the instructions are well laid out on the web. Nobody else on your block (heck: in your county!) will have one.
Reece
Old 09-06-2010, 07:28 AM
PaulOF's Avatar
PaulOF PaulOF is offline
Oh my. It is well that I do not live in Chicago, for I would surely risk deeply annoying my wife by going after yet one more "large thing for which we have no room." Phonos are my second love (after aforementioned wife.)
Old 09-06-2010, 10:57 AM
Bill Cahill's Avatar
Super Moderator
Post
Hope I didn't step on anybody's toes. If I could work out shipping with him, I wrote that I will take it. I had that model as a teen ager.
I like the lighted adjustable strobe on turntable.
Yes, it's a nightmare.
Motor is mounted on its' side.
Large beveled disc.
Main wheel rides up, and, down on that to adjust speed.
Small wheel on shaft drives turntable.
Come to think of it, I think it's the motor that moves up, and, down.
Neat mechanism, though I admit tricky.
Plus, look at that hole someone kicked in the side. Ouch!
Bill Cahill
Please join my forum.
Old 09-06-2010, 11:29 AM
It looks like the record changer is in bad shape -- the pickup arm looks as if it's been torn off its pivot, the record spindle is bent ... and I don't know what else could be wrong. This unit will need a major overhaul before anyone can even think about using it, with the bad wiring and all (probably rubber-covered wire that's deteriorated with age).
I'd replace the Beam-O-Lite record changer with a modern one, unless you want to preserve the authenticity of this unit. There is a phono preamp tube in the radio/amp chassis (type XXFM) that will have to be removed or bypassed if a modern changer is used; if you leave the preamp in the circuit, the output of any modern cartridge will overdrive the tube many times over, resulting in horrible tone quality.
The Beam-O-Lite pickup was a rather low-output device, hence the need for the preamp. Moreover, it is a single-speed changer (probably 78 RPM), so unless you have a bunch of 78s you'd like to hear again (or transfer to tape), I'd replace the changer with a modern four-speed one, if such can still be found in this age of CDs and mp3s. If you are intent on replacing the Beam-O-Lite changer with an authentic one, however, I'd look for a junker console similar to the one you have and get the changer from it. I don't know how common these combinations are anymore, but you could probably still find one on eBay or even CL if you do some looking. Finding parts for one of these old changers could be like finding a needle in a haystack.
Old 09-06-2010, 03:08 PM
Found a bit of info about the Beam-Of-Light changer here:
http://www.philcorepairbench.com/phono.htm
I have never seen one before. Pretty impressive use of technology for the day... no wonder you guys want one!
Last edited by jr_tech; 09-06-2010 at 03:14 PM. Reason: add picture from linked article
Old 09-06-2010, 03:19 PM
Also check out the Ampicokids's demonstration here: http://www.youtube.com/watch?v=BMYYGWmTw1c
He also has restored the Mystery Control! http://www.youtube.com/watch?v=5SDWNGrm9Gk
I think I'll have to pass on it, but if I did pick it up I would certainly attempt to restore the changer.
Old 09-06-2010, 04:05 PM
Nice demos! It looks like a slightly different model changer with a straight spindle and 3 supports to drop the records. Also, there is a second tone arm... was this a disk recorder as well?
Old 09-06-2010, 04:20 PM
Steve K Steve K is offline
Yes, that second arm was for recording.
Steve
Old 09-06-2010, 05:04 PM
sean's Avatar
sean sean is offline
That is a 1942 changer. The spindle is supposed to be "bent" that way. When the stack of records are loaded on they sit at a slight angle between the spindle and the sorting mechanism on the left. The tenite cover over the Beam-of-Light assembly might just be loose, the tonearm looks to be mounted properly to me. I would urge anyone who buys this radio to keep the original BOL changer in it.
When I get done working on stuff for other people I have the changer from my 42-1015 to finish restoring. My changer has been modified to move the motor from a horizontally oriented shaft mounting to a vertical mounting with an idler wheel. Because of this the speed adjustment was disabled. I understand that this was a retrofit that Philco offered for these changers but I have not been able to find any documentation on it.
Sean - WØKPX
Old 09-06-2010, 05:14 PM
The listing has just been deleted so I guess someone got it.
Sean:
The retrofit to which you are refering was Philco's kit number 45-1548 for the 1942 changers. It is listed in the Philco parts and accessories catalogs.
Steve
Old 09-07-2010, 11:47 AM
This console must have been close to top-of-the-line when it was new, with a price tag to match.
I just looked at the Philco Repair Bench article for this and found that the record spindle in fact has a bend near the top, so obviously it was designed this way (as was mentioned). The record changer mechanism is nothing like later three-speed designs, so it must have been one of the first changers to be used in mass-produced combo consoles. Also, I noticed a reference in this thread to a retrofit kit offered by Philco that repositioned the phono motor, and a note that, when the motor was repositioned, the speed controls of the changer were disabled. Was the Beam-of-Light changer originally a two- or three-speed unit, with the turntable speed continuously variable by a mechanical control? If so, I would think this changer also could play 33, 45 and even 16 RPM records, as well as 78s, when the other types of records became available after the war. The tracking force of the Beam of Light pickup arm must have been enormous compared to later four-speed turntables, so modern microgroove records could be damaged or destroyed after one or two plays if played on a BoL changer.
Another question I have concerns the Beam-of-Light pickup itself. While reading the service notes for this unique reproducer, I noticed that the beam from the exciter lamp is supposed to be no wider than 5/32 of an inch. How was the width of the beam determined? I don't know if there were any instruments available in the '40s to measure much below an inch. The only thing I can think of regarding this is that there must have been a special tool (proprietary to Philco and available only to its authorized service centers of the period) that was designed especially to aid the service technician in adjusting the BoL's beam width. I can't imagine anyone being able to adjust the beam by eye and get it even close to the correct width.
Old 09-07-2010, 01:53 PM
Super Moderator
Post
The simple reason for the variable pitch control was because not all records were 78 rpm. There were variables, including 76, 80, and, 90 rpm.
This was not meant for 16 rpm records.
Used a 78 size stylus.
Wasn't the first record changer. Merely the most deluxe, with the first to have variable speed with strobe.
Problem was it was difficult to repair.
Philco didn't want to keep supplying the repair parts when these deluxe machines just didn't sell well due to their price.
Bill Cahill
I never heard from owner.
