Old 09-07-2010, 07:06 AM
devoid's Avatar
devoid devoid is offline
NA Volvos and Amplifiers
Panasonic CT35G25 help
Just shy of full deflection on the right side. I have no manual to check B+. But doesn't vary much with screen brightness. I've resoldered the iffy connections and checked the caps. I haven't found jack on the web about this set. Thanks
What I don’t want is music that was written to be recorded.
Old 09-07-2010, 08:31 PM
Sure it's not a CT35G25B?
What is the input source? The reason I ask is that someone else seems to have had your problem:
http://forums.techguy.org/do-yoursel...nter-help.html
I've got a Panasonic Viera that has horizontal shift - but only on DVD or Converter box. Off air, it's centered. Dunno why it shifts to the left - I tried all modes - letterbox, fill, or 4:3, all the same. I did find a document in Portuguese that suggested the horizontal count-down resonator may be slightly off. (Horizontal frequency is determined by crystal resonator off of the jungle chip in mine)
Do you have access to the Sams? (4548)?
Cheers,
USN RET 22YRS (Avionics/Cal)
Old 09-08-2010, 08:50 AM
devoid's Avatar
Not exactly sure what it is really as I damaged the label with the model number on it while cleaning the set. It was made in 2000. And a month ago I just tossed a file cabinet full of Panasonic manuals. Who knew? I'm just running it from cable right now. QVC and whatnot. It's just a big cheap 4:3 set with a good CRT in it. The lack of deflection is about half an inch at most. The set has to run about an hour to get to that point.
