Old 09-11-2010, 01:31 AM
Adam's Avatar
Adam Adam is offline
ctc-9, detroit cl
http://detroit.craigslist.org/wyn/atq/1947256526.html
Old 09-11-2010, 09:04 AM
rcafan rcafan is offline
Smile Craigs List CTC-9 near Detroit(Canton)
Just came home with the CTC-9 in tow. Cabinet is 8/10. Blonde finish
is great. It has some flaking varnish. Pix tube is rather dull on startup
and after a few minutes will brighten. A brightner would help. Set is
actually working with no hum.
Old 09-11-2010, 01:03 PM
marty59's Avatar
marty59 marty59 is offline
If the tube is coming up after being on for awhile, it may be better to rejuvinate it with a good tester/rejuvinator, or at least check it with one. If the tube will track and cut off correctly those are good signs for either a successful rejuvination or leaving as it is now. I shy away from brightners if at all possible but as a last gasp of operation to an otherwise un-savable tube then that may be your only choice. But don't use one and take away any salvagable life/longevity your tube may have.
Old 09-12-2010, 10:09 AM
Ctc9
Thanks for the hint
Old 09-13-2010, 02:53 PM
sanjarali sanjarali is offline
Banned
It is very sad upon my mountain to not ownership of this television set! I wish it would have in que been viewed primary by myself.
It is that I am wishing you much success early colour television.
Old 09-13-2010, 03:00 PM
oldtvsandtoy oldtvsandtoy is offline
Banned
How many rca color sets do u need? When u coming over to fix my set?
Old 09-13-2010, 03:29 PM
David Roper's Avatar
console lover
sanj: I don't think anybody wants to see a 9 with a silver spray-painted cabinet.
Old 09-13-2010, 07:25 PM
miniman82's Avatar
First Light: 1952-2011
Or a screwdriver through the screen....
Evolution...
Old 09-14-2010, 02:03 AM
AUdubon5425's Avatar
I didn't know about the mountains skirting Detroit...
AUdubon5425 Youtube Channel
Old 09-14-2010, 07:06 AM
tubesrule's Avatar
tubesrule tubesrule is offline
Sure, there's Mount Clemens :-)
(hint: it's as flat as a pancake)
Old 09-16-2010, 01:36 PM
Thanks to MARTY59 I did check the tube and did a rejuvination The checker now
reads at a high normal good and there is a bright tracking raster, Thanks
