Old 10-10-2010, 09:41 PM
what CRT is this?
http://cgi.ebay.com/HUGE-Vintage-RCA...item1c1626c542
This is local and I could go check it out if I knew the tube (and if the guy would let me).
Old 10-10-2010, 10:01 PM
Tom Albrecht's Avatar
It looks like a 19AP4, although there is no way to be sure. There is a discussion about this tube here: http://www.antiqueradios.com/forums/...er=asc&start=0 . If you are in a position to go test it, it might be big help to everyone involved.
Old 10-10-2010, 10:12 PM
I will see if I can get a hold of the seller to test.
Old 10-10-2010, 10:38 PM
well I asked if ok to check tomorrow, I will let you know what he says.
Old 10-11-2010, 11:27 AM
kx250rider's Avatar
REAL TVs have TUBES!
I'd bet it's a commercial 19AP4, but I don't show that number in the RCA Tube Manual. It's a standard gun, so it should work in a 19" TV. The only question would be phosphor speed and color.
Charles
Old 10-11-2010, 11:36 AM
The tube is probably a 19AP4. The base shows RCA service co. When RCA service co. repaired sets under contract, they would milk their crt's until the bloody end. Then they would replace it with one of those tubes. The 5839 is a warrantee code date.
well its too late to check now, did not hear back from him and I have to get back to work, so does not look like I will be getting out there to test.
