Old 10-15-2010, 05:45 AM
cwmoser's Avatar
cwmoser cwmoser is offline
Predicta tv chassis repair service = $149.95
PREDICTA TV CHASSIS REPAIR SERVICE = $149.95
Holy Moley!!
I couldn't compete with this guy:
http://cgi.ebay.com/PREDICTA-TV-Chas...item27b597e044
CW
Old 10-15-2010, 08:17 AM
miniman82's Avatar
First Light: 1952-2011
It says other non-predicta chassis as well, guess I should have sent him my CTC-7.
Evolution...
Old 10-15-2010, 10:09 AM
He's been offering repair services for years although not this cheap. He used to sell parts too.
Old 10-15-2010, 10:10 AM
Tom Albrecht's Avatar
Yes - that's a good deal, and priced right given the value of Predictas (not as high as they once were). He's not making much money, but probably gets quite a bit of business this way.
Old 10-15-2010, 10:50 AM
RDusel RDusel is offline
I've often wondered at this price if he is doing a full recap or just changing the failed parts. Seems rather cheap to me as well..
Old 10-15-2010, 10:55 AM
cwmoser's Avatar
My Capacitor and Resistor order for the Emerson 639 TV I restored was $75.00.
The service techs who work on my Heat Pump charge $95.
Ditto for the auto mechanic.
It took me many hours to recap and check resistors and then more hours to test the darn thing.
Carl
CW
Old 10-15-2010, 11:21 AM
I asked him about this last year. He told me he replaces the multi-section electrolytics with discrete caps. i.e. no restuffing. All paper caps and bad resistors are replaced.
Not sure if he removes the circuit boards or replaces them from the top.
Old 10-15-2010, 12:27 PM
wonder what the deal would be if bad tube sockets or bad fly?
Old 10-15-2010, 02:34 PM
He's not getting rich on a per-hour basis, but I'll bet the work goes pretty quickly once he's done a few dozen Predictas. When I pulled the board on mine for a second time, I did it much faster than the first time.
And who knows, an inexpensive Predicta offer might act as a "loss leader" to bring in additional work that's more interesting/lucrative.
Old 10-15-2010, 06:09 PM
mbates14 mbates14 is offline
possible because of the bad economy? at our shop we had to lower our repair prices to almost peanuts JUST to get people to come in through the door. and still that isnt much..... Its low enough to make it almost non-survivable in real-life conditions, but i want to keep the business going as long as i can to get through this rut...
Old 10-17-2010, 10:50 PM
Seems he's asking $295 for the 17" versions. http://cgi.ebay.com/17-PREDICTA-TV-C...-/170554141249
Old 10-18-2010, 10:59 AM
kx250rider's Avatar
REAL TVs have TUBES!
I know him; met him through some eBay sales about 8 years ago... Name is Ross. He's a good guy, honest, but I haven't had him do any work for me as of yet, so I can't vouch for it as of this time. The price is right, but I would ask whether he pulls the PC board off the chassis to recap, or if he just snips the leads on the component side of the board. When I used to do a lot of Predicta restorations, I charged a lot more, but I also pulled the board off and fully removed/replaced caps. That's a PITA of a job, as the board has to be unwired and unsoldered from all the ground lugs to be pulled off.
NO! I don't do those anymore, so no competition here at any price.
Charles
Old 10-18-2010, 12:19 PM
I would imagine he snips and splices. Although it isn't quite a pretty, it's probably better from a reliability point of view, since the less stuff you disturb, the more likely it's going to stay working.
Predictas don't have very many paper capacitors. Not too many tubular caps, and some of the tubulars are not paper. Probably less than 10 paper caps that have to be replaced in a Predicta.
I could imagine these repairs go pretty quickly, since he's probably quite experienced at Predictas and knows exactly what needs replacing, and what symptoms mean what on that chassis.
Old 10-18-2010, 03:10 PM
Dave S's Avatar
Dave S Dave S is offline
<-- Me and my "first" TV
If I had a rare or really mint condition set, I'd go to the trouble of pulling the board. I actually did that on one of my Predictas (hardly a rare or mint set, but hey, it seemed like a good idea at the time...) Otherwise, for a garden-variety set, I have NO problem just working from the top. It's always entirely upgradable to a fussier restoration in the future if someone should choose to do so. And as Tom noted, I'm less likely to cause other problems in the process.
Many years ago, a company (Mallory?) used to sell kits of repair parts that I think were called "squigs" which were little coils of wire that looked like very small springs, with an inside diameter the same size as capacitor leads. You would insert the coil over the cut end of the wire left from the part that had been removed. Then you'd insert the end of the replacement part into the other end of the coil and solder it. A very easy and secure repair (although admittedly it didn't look as nice as unsoldering the old part.) A guy in our club figured out how to make a tool out of brass tubing and piano wire to make it easy to wind those tiny little coils. It makes it a LOT easier to replace parts as long as you're not shooting for a pristine restored appearance.
Old 10-18-2010, 03:19 PM
yea and I think they came coated in solder as well.
