Old 10-29-2010, 11:38 AM
miniman82's Avatar
First Light: 1952-2011
Project VT-71 nearing completion!
I got tired of refinishing the cabinet for now, so I'm moving on to trying to figure out why the sync sep circuit is unstable. Set works pretty well, but it randomly looses sync at times.
Evolution...
Old 10-29-2010, 03:50 PM
batterymaker's Avatar
Repro Battery Builder
Finish on that cabinet is dee-licious.
Old 10-29-2010, 08:05 PM
Lookin' good
Is it loosing horizontal or vertical sync ?
Old 10-29-2010, 09:39 PM
miniman82's Avatar
It's bad horizontally, and the hold control is very sensitive. After it's been on for a little bit, it starts tearing horizontally and the hold control won't bring it back. There's still a few micamold caps in there, so I should probably get the remaining few.
Evolution...
Old 10-29-2010, 09:55 PM
Definitely replace the micamold paper caps masquerading as micas. If you do replace the two mica caps in the horizontal output (680pF & 900pF), make sure you use 1000v mica caps.
Old 10-30-2010, 09:40 AM
miniman82's Avatar
I have a 560 @ 1kv I could use in place of the 680, but the closest thing I have to 900 would be .001uf @ 600vdc. How critical do you think those 2 caps are?
Evolution...
Old 10-30-2010, 11:26 PM
I think they're fairly critical, but you might as well give it a try. I used a 910 pF mica cap.
