Old 12-02-2010, 05:27 PM
steveo_118 steveo_118 is offline
VK Member
Just picked up this 1965 magnavox 546 console tv...need some help!!
Hey guys, we just picked up this console tv from a local thrift store... stereo and phonograph worked great, TV would turn on but would shut off after a few seconds. We tracked it down to a cracked board... looks like someone pushed down too hard on one of the tubes. We pulled the board, re-soldered the bad connections, and that fixed the short. The tv now stays lit, and we are getting audio, but we cant get any video... just a bunch of lines.
Judging from an ad we found posted online we figured the tv is a 1965 magnavox eastern contemporary theater 546, but I don't know the chassis code... I dont even know where to find it on the tv.
Anyone have any thoughts on what we might need to look for? All the tubes appear to be lighting up except for the video and sync amp, which is shielded and we cant get the shield off to see if its lighting up. We are new to this whole vintage tv thing and are at a loss. We ordered both of the tuner tubes as well as the one for the amp to be safe, but we might be missing something simple. Any advice? Thoughts? Information on this particular model or something close? Any help would be much appreciated.
Thanks!!
Steve
Old 12-02-2010, 05:58 PM
Kalamazoo-DJ's Avatar
Kalamazoo-DJ Kalamazoo-DJ is offline
I have 2 very similar to that one U45 If I remember correctly I think Dave WM identified mine just by looking at my chasis picture. I am clearing some of my inventory BTW. I have mine in my album, take a look
Old 12-02-2010, 06:08 PM
holmesuser01's Avatar
I wish I could find a roundie Magnavox like that. I only seem to find 23, and 24 inch black and white sets. Not that I am complaining.....
Old 12-02-2010, 07:44 PM
what is the video source?
Old 12-02-2010, 07:58 PM
miniman82's Avatar
First Light: 1952-2011
My advice: don't operate anything in this set until you at least replace all the wax and electrolytic capacitors inside it. There is the very real possibility of them exploding from the stress of being used suddenly after years resting, ask me how I know. After you do that, then you should investigate the loss of video. On the plus side, you already have a raster on the screen so that means 99% of the set's electronics are already good.
Evolution...
Old 12-02-2010, 08:24 PM
mikeh's Avatar
mikeh mikeh is offline
HI,
I have a unit similar to yours, mine is 1963 or 64 with vhf only. On the chassis for the tv you should see a unit number similar to u43-01-00/10 or something similar. Go the the Sams photofacts web site and then you can use this chassis number to get the photofact number, my tv was in Sams set 708 folder 2.
Mike
Old 12-02-2010, 09:39 PM
marty59's Avatar
marty59 marty59 is offline
These model Magnavoxes will put out a nice picture! They will also cook Flybacks so Horizontal Output Tube Current is critical...but you've got some work to do before getting to that point. As mentioned, I would not power this up any more until you recap it and give it a good visual of all connections and components.
The tubes that are PC mounted may be hard to pull after years of being inserted so do take your time wiggling any loose, especially if there's some heat damage. I would remove the chassis before removing any of the tubes and check those areas where the tubes mount as it would be a good idea to test them too.
The last thing you want to do is induce more cracks!
Old 12-03-2010, 09:03 AM
A little De-oxit at the base of tubes on a board will make them come loose without stressing the board. VERY nice set BTW
Old 12-06-2010, 01:03 PM
VK Member
Hey guys... thanks for all the responses. We replaced the video and sync amp tube as well as the RF amp and the osc & mix tubes in the tuner... those were the original primary culprits... no difference. the Z Demod tube is bad... we are ordering a replacement for that one...would that cause the issue we are seeing? We have scrolling horizontal lines on every channel. Im attaching some pics of the board as well as the sockets for the Z and X Demod, which look bad. Also, can anyone tell me where we should start with replacing the caps?
Or possibly anyone in the sacramento, CA area that may want to come take a look at it and provide us with some assistance?
Old 12-06-2010, 01:28 PM
Ex-Philco
The tube sockets were a common problem with that chassis.
For best results, break the socket apart. Heat one pin at the bottom tip and push it out gently. Do not heat the PC board. It cannot stand much heat.
Replace with new PC sockets and apply heat to the socket pin.
Old 12-06-2010, 02:07 PM
VK Member
Also, no matter which channel we turn to, we get the same thing... brightness doesnt seem to change anything.
Our video source is a laptop: vga --> rca video --> coax --> antenna, but we cant even get snow. just the horizontal scrolling lines on every channel.
Old 12-06-2010, 02:15 PM
sorry not up to laptop speed, it is an RF signal correct? out to channel 3 or 4 or what ever the RF is at? oh and a matching transformer to get to 300ohm.
Old 12-06-2010, 02:53 PM
VK Member
yeah I am running through a RF converter out to channel 4... we get beautiful audio but no video. When disconnected fromn the RF source, I can hear snow, I just cant see snow. So I'm thinking somewhere along the way it's losing the video signal?? How do I trace down the video signal?
Old 12-06-2010, 03:35 PM
messed with the fine tuning I presume? just need to cover the basics.
I would look at the video amp tube, maybe an open plate load resistor however with out a schematic its hard to tell exactly where to start.
if you have a scope you would need to trace the signal at the output of the video detector, looking for a composite video signal.
Old 12-06-2010, 04:36 PM
VK Member
yeah messed with the fine tuning... has zero effect. We are probably going to start testing the signal at various points and hopefully chasing down where the bug is.
The only code I was able to pull off the chassis was R315... does that sound like a possible chassis code for the tv? Sams does have a listing for a magnavox R315, but before I jump to buying it, I thought I would check with someone to see if that sounded right?
