Old 12-07-2010, 11:45 PM
miniman82's Avatar
First Light: 1952-2011
Perhaps someone can use this?
Substitute CRT: http://cgi.ebay.com/Vintage-CRT-Subs...item2c5935b07f
(no affiliation)
Evolution...
Old 12-07-2010, 11:47 PM
David Roper's Avatar
console lover
Not at that price!
Old 12-07-2010, 11:56 PM
Those 5AXP4 tubes are very useful but they can be had for $20 without the fancy box.
Old 12-08-2010, 04:02 PM
mbear2k mbear2k is offline
I picked up the exact same model on epay for $18 plus. They are handy - but not $300 handy!
Old 12-08-2010, 04:21 PM
cwmoser's Avatar
cwmoser cwmoser is offline
I picked up one a few months ago for less than $10.
Mine was not as nice as that one and the rubber bezel was broken and crumbling.
I removed the 5AXP4 from the box and use it without the test box.
Makes a nice test CRT.
Carl
CW
Old 12-08-2010, 10:41 PM
I've got one; handy for use with sets that mount the crt/yoke to the cabinet, like a couple Philcos I have. Don't connect the yoke connections tight enough and you can burn a dandy hole in the phosphor! Nice orange glow...ouch!
Picked mine up at an antique store, seller thought it was some sort of flashlight! I think I paid $10 or $15.
Old 12-14-2010, 05:45 PM
Here's a well used 5AXP4 a bit more reasonably priced: http://cgi.ebay.com/5-inch-round-70-...-/230563725755
Old 12-14-2010, 07:33 PM
Doesn't the B&K TV analysist use the same tube for the spot scanner?
Old 12-14-2010, 08:06 PM
Nope. It looks similar, but is actually an ultraviolet CRT
Old 12-14-2010, 08:19 PM
Tubejunke's Avatar
Hey, this is what I kept mentioning needing in my Zenith Space Command post. To me, this thing essential in the repair of a set that was not designed to have the crt come out with the chassis, and there were a lot of them. If anybody gets a lead on one please let me know. I saw the post about a "well used" tube, but if I get one I want to get a good one. This would help me tremendously!
Old 12-14-2010, 08:25 PM
Well, it doesn't mean it's bad. The one I got off eBay looks just as worn and scratched, but works fine. They're pretty hard to kill.
Old 12-14-2010, 09:45 PM
Note that there are different kinds of test tubes, and any given one will not necessarily substitute for every other tube ever made. Here's a website where you can look up tube data sheets:
http://tubedata.tigahost.com/tubedata/
The data sheets will show the pinouts, deflection angles, etc., for both tubes, and thus you can tell whether test tube X can substitute for tube Y.
Old 12-14-2010, 10:27 PM
The 5AXP4 will sub for most late 40's round B&W tubes like the 10BP4, 12LP4, 12QP4, 12JP4 etc, it will NOT sub for a mid 50's 21" tube however, the HV is too much for it to handle, it arcs inside, I know this for sure... somehow...
The large neck rectangular tube is an 8YP4 or an 8XP4, can't remember which is which, they will work for the big rectangular tubes.
Old 12-14-2010, 11:43 PM
Tubejunke's Avatar
I don't get it really, because the neck diameter and socket footprint is the same for a 1947 10BP4 as it would be for a 1956 21ZP4 or my 1958 24AJP4. I can understand the problem with high voltage arching. Perhaps there was a procedure or special connector to control second anode input to the tube. Anyway, if anyone spots one that is suitable for my 24AJP4, please drop me a line. Thanks!
Old 12-15-2010, 12:00 AM
The 8XP4 is the rectangular version. Max 22 kV: http://tubedata.tigahost.com/tubedat...168/8/8XP4.pdf
5AXP4 is round. Max 18kV: http://tubedata.tigahost.com/tubedat...68/5/5AXP4.pdf
The rectangular 8XP4 will work in round CRT sets, but the deflection angle is different so the image will be clipped or distorted.
