Old 01-17-2011, 11:45 PM
Arrrrgh!!
Way to ruin a great TV!:
http://cgi.ebay.com/VINTAGE-1951-BAK...item53e5c44c15
Holes cut in top to feed the fish even
Old 01-18-2011, 12:01 AM
Ugh
Those four knob in the middle are totally wrong. He ruined a set of four knobs from a 20X122 or similar. Including the channel selector which has been cut down to fit!
Kevin's 20Z1 chassis goes with this cabinet, but those holes really ruined it
Old 01-18-2011, 12:04 AM
They only drilled some small holes so it could be fixed and un-fish-tanked at this point if you wanted to pay $99 for a cabinet.
It's missing the door and the knobs have been glued on, hopefully only Hot Glue and not Epoxy.
Old 01-18-2011, 12:14 AM
Kevin Kuehn's Avatar
Workin' Late Again
Thats too bad, I could have even used those knobs.
Kevin
Old 01-18-2011, 12:31 AM
David Roper's Avatar
console lover
Hmm. That's a lot closer to reality than the $350 or so from last time around. Gonna have to give this some careful consideration.
Old 01-18-2011, 12:53 AM
Ugh
Hopefully, the correct number of knobs for the middle is Zero... mine just has knurled shafts in that location.
Forgot to mention on the eBay auction post above, but it should be obvious "NOT AFFILIATED !"
Old 01-18-2011, 01:24 AM
Yeah, it looks ridiculous, they just glued a bunch of unrelated knobs everywhere to hide the fact the door is missing.
Old 01-18-2011, 01:37 AM
Yes, it should just be four knurled shafts
Old 01-18-2011, 03:13 PM
John Folsom's Avatar
Tragic. But I kinka like the antenna...
John Folsom
Old 01-18-2011, 06:29 PM
I asked the guy whether he still has the insides and mentioned that it's worth more as a complete TV than as an aquarium. Guts are gone.
Old 01-18-2011, 06:30 PM
Unhappy
Which is worse, did he ream out the shaft holes bigger to accept those knobs, or cut the shafts off the knobs? Probably make a mess of that plastic bezel removing those knobs.
Old 01-18-2011, 07:07 PM
Workin' Late Again
I'll volunteer this bezel and partial knobs if someone wants to go for that poor thing. Of course the door was busted out of this one too. I also have the chassis with a good crt, but it would be killer to ship the thing. Otherwise I'll just set on this stuff in hope that a nicer cabinet will one day come my way.
Kevin
Old 01-18-2011, 07:20 PM
Workin' Late Again
That knob on the left appears to be glued on with clear silicone; that being the case, those would pop off without much damage. At least the speaker is included, and the antenna is really cool. I just can't invest $150 plus to have thing shipped. Anyone know where the seller is located?
Kevin
Old 01-18-2011, 08:02 PM
Kevin
Oxford, MI. ebay hides the item location under the 'Other item info' link on the right.
Old 01-18-2011, 08:39 PM
Workin' Late Again
Whoever did this fish tank obviously had access to more than one Admiral
Kevin
