Old 01-30-2011, 08:44 PM
Kico's Avatar
Kico Kico is offline
Here's looking at you kid
My new 50 cent tube amp...
Local tag sale find today for half a buck -- it even works without a hummm in sight. Two 50EH5's and one 7025. Probably from a phonograph or small console.
Wonder what wattage?
"I whisper but my horse still doesn't listen."
Old 01-30-2011, 09:16 PM
Exclamation
Be careful, that's a hot chassis. One side of the powerline directly connected to the amplifier circuits, without any isolation, except maybe a capacitor. No power transformer. Looks like you have a bench isolation transformer. You can get an isolation transformer to wire into the amp at www.tubesandmore.com their P-TN-51X for about $22
The 50EH5 can produce about 1 watt. I'd replace the capacitors, those ceramic cylinder caps are just wax paper inside, which get leaky.
Old 01-31-2011, 09:39 AM
Hi Bob. Can you tell myself and others What the difference is between a 50EH5 and a 50C5? Also a 60FX5? I know the 50EH5 uses a 68 ohm cathode resister.
Old 01-31-2011, 02:03 PM
That's a cute little amp. I agree that it's probably from a small console or phonograph, that's the last place I saw one like that.
I think this will fit in better here with the Antique radios so I moved it.
Old 01-31-2011, 09:47 PM
Chad Hauris's Avatar
This looks like a Magnavox amp. The 50EH5 has higher transconductance than the 50C5 which I think makes it a higher-gain tube.
Chad Hauris
Old 02-01-2011, 07:27 AM
Reece's Avatar
Reece Reece is offline
The tube brands may be a clue to the provenance.
Reece
Old 02-01-2011, 06:56 PM
Hemingray's Avatar
Hemingray Hemingray is offline
Vintage Geek
Definitely from a phonograph. I used to have one of these myself, Mine however, had come with 2 50C5s and a 12AX7. Kinda wished I kept it.
Death: Man how old is this TV?, You probably get the DuMont network on this thing!
