Old 02-11-2011, 12:22 PM
bob91343 bob91343 is offline
Plugs or cable needed
I need a cable to connect an external VFO to a Kenwood TS-820S. Alternatively, a pair of 9-pin plugs, same as a standard tube plug.
Anyone have such in junkbox?
Old 02-15-2011, 08:34 AM
hvlee's Avatar
hvlee hvlee is offline
VK Member
Try these people
If you haven't already, try the Kenwood reflector at QTH.net. There's a lot more traffic on the QTH groups than here and the expertise will be more specific. Someone may have what you need or know a source. Sometimes someone says, "Hey I've got a box full of those. How many do you need?"
Sorry if you already know this but here's how:
Go to QTH.net
Select "Email Mailing Lists" from the menu on the left
Select "Directory of Lists" ditto
Select "Kenwood" from the list and follow directions.
If you're not familiar with email reflectors, all of the activity is "reflected" to the email address you registered rather than logging in to a forum.
I had a similar problem in the 90's. I had the cable but it was mostly disconnected from one end and I didn't have any luck soldering to the little buttons on the plug. I found plugs with real solder lugs at a hamfest but never got around to fixing the cable and passed them along to the guy I sold it to.
Good luck,
Harry, KT4AE
"Mostly Hallicrafters"
Old 02-15-2011, 10:22 AM
hvlee's Avatar
VK Member
I see we've been there
I see I gave you the QTH info back in the S-20R thread.
Sorry, I've slept since then.
Harry
Old 02-15-2011, 12:04 PM
Thanks, I'll check it out!
Old 02-23-2011, 04:27 PM
I have 4 used plugs
Bob, I've got 4 in very good (used) condition - they have different colored covers - one white, one blue, one pea green, and one kelly green. PM me if you still need these. - yours for postage. Just to be clear, these are 9-pin male plugs with the same base as a 9-pin miniature tube, like a 12AX7.
Cheers,
USN RET 22YRS (Avionics/Cal)
Old 02-24-2011, 01:48 AM
PM sent.
Old 02-25-2011, 06:50 PM
Bob, the Postman got them this morning - postal service tracking # 9101150134711599893506. A whopping 1.92 to mail. Hope they work for you/your friend!
Cheers,
Old 02-25-2011, 06:58 PM
Brian, that's great! Give me your address and I'll have some gold bricks turned into cash and mail the money to you. Or more precisely, I will have Bob mail it to you.
