Vertical 'jitter'
Help me with a problem please.
I have a '48 Stromberg-Carlson # TV-12, fully recapped & operational. Works fine, except for a very, very slight vertical 'jitter' which is not immediately noticeable - but becomes obvious if you try to watch a program. Where is the problem? I can't locate it. Thanks for any guidance. |
HI; I had the same problem with my philco projector set and found out after looking over and over , that I had some cap connections touching and also found bits of solder here and there in the vertical section.
Dunno if I can help, but I had an KCS-8? RCA with a jitter that drove me crazy. Problem was some increased value resistors between the vertical sync amp and the oscillator.
If your Stromberg is based on the Dumont RA-103, the schematic will look like the one I've attached. Check the three 10K resistors and the two caps hanging off them. They, as a circuit "clean up" the vertical sync for the oscillator. If your height and linearity are A-OK, I'd guess the problem to be among those resistors. RCA used 22K ohm resistors - I still have one of the bad ones hanging from a bench lamp mount above the workbench. It reads 34K, a wee bit out of tolerance. Cheers,
Brian USN RET 22YRS (Avionics/Cal) CET-Consumer Repair and Avionics ('88) "Capacitor Cosmetologist since '79" When fuses go to work, they quit! Last edited by Findm-Keepm; 09-29-2017 at 06:39 PM. |
Thanks for replies.
Yes Brian, its basically the Dumont 103 chassis. I'll definately check out the resistors, probably will be a few weeks, I'm leaving tomorrow for awhile. Will let you know. thanks....... |
