Old 02-15-2011, 01:50 PM
hposter hposter is offline
hposter
RCA's use of 'Domino' resistors
Does anyone know when RCA phased out the use of 'Domino' style CAPACITORS, and went to the more modern cylindrical type? Either in TVs, or in radios?
Capacitors, capacitors, capacitors...that's what I meant to say !!
Old 02-15-2011, 04:27 PM
electroking's Avatar
a- v- karma member
Aren't those parts capacitors?
Old 02-15-2011, 04:29 PM
John Folsom's Avatar
I don't know what a domino resistor is.... how about a photo of one?
John Folsom
Old 02-15-2011, 04:50 PM
David Roper's Avatar
console lover
My Emerson 699 TV had a cathode resistor to the HOT that looked for all the world like a big Micamold cap. I assume it was an original part from 1951.
Old 02-16-2011, 09:08 AM
hposter
Domino Caps
Yes, Capacitors--sorry about that!!
Does anyone know when RCA phased this style cap in their TV chassis?
Old 02-16-2011, 10:20 AM
Harry, those domino style silver maca capacitors were used in sets well after 1960. Have you taken an inventory of date codes on the tubes in the chassis? The can electrolytic capacitors may have date codes, and any part numbers which start with 274XXX are RCA numbers and the XXX is a date code.
John Folsom
Old 02-16-2011, 11:21 AM
ctc17 ctc17 is offline
60s! those things were mostly gone by the mid 50s. Change them, the ones with more than a few volts applied slowly break down after the set has been on for awhile and cause all kinds of problems. They will recover after the set has been off for awhile. They will drive you nuts
Old 02-16-2011, 05:28 PM
console lover
I'm going to make a prediction...just a stab in the dark here...that Harry is not going to be changing any of those.
Old 02-16-2011, 06:25 PM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
Aw crud... my RCA T100 has alot of those.. Those have to be yanked too?
Steve
Old 02-16-2011, 08:11 PM
I don't automatically shotgun all micas as I do paper caps. Once the electrolytics & paper (or molded paper) caps are all gone, I see how the set works, and replace micas on a case-by-case basis if a symptom points to one.
My T-100 plays like a champ after a standard recapping -- with all of the original micas still in place. Your mileage may vary, of course.
Old 02-16-2011, 09:45 PM
miniman82's Avatar
First Light: 1952-2011
I had a Philco that required total replacement of all caps, even those dominos. I found out why later after I broke one apart- it was a PIO masquerading as a mica!
Evolution...
