Old 02-19-2011, 09:35 AM
testing tubes similar numbers
hi all i have a 6dq5 tube to test but i only have a listing for a 6dq6 could this be tested. and others with the same 3-4 digits but with some other letters on the end confuses me as to if i can test tubes with extra digits on the end, or should the first 3-4 letters or numbers be the same to test no matter whats on the end.
Old 02-19-2011, 11:34 AM
Reece's Avatar
Reece Reece is offline
Similar but different tubes in rating and some pin connections. Compare the suggested subs on the attached.
http://www.nj7p.org/Tube4.php?tube=6DQ5
http://www.nj7p.org/Tube4.php?tube=6DQ6
Reece
Old 02-19-2011, 11:47 AM
yes little difference, pin 8 so i dont know if it would be safe for the tube to be tested.
Old 02-19-2011, 02:26 PM
stusnyder's Avatar
If it does'nt sub out to anything thats listed on your chart, I would'nt trust testing it. Your tester manufacturer might have updated charts someplace.
So many different tubes over a 50 year timespan...thats why I own more than 1 tester.
Old 02-19-2011, 02:44 PM
i figured so, ok thanks, ill look around for other testers or an updated chart for my tester.
