Old 02-23-2011, 12:28 PM
chipper chipper is offline
25Z6GT Rectifier(V15) circuit/Delco TV-71A
HI: This is used in a Delco model tv-71a/Sams set 99a/folder3
My set looks to have never been worked on and I have a question about the 2 - 30mrd/200v caps used here. the print shows at pin #3 neg and positive side to ground for C 59A cap together with positive side for C59A and the neg side goes the R74 1200 ohm 1 watt resistor. This set uses a 2 in one capacitor with both 30mfd inside it. They have only used 1 cap which is the C59A at pin #3 and the lead for the C59B has been sniped off and not used. Maybe some one you has done a restoration of this set can tell me why this was done? thanks
