Old 04-16-2011, 07:12 PM
Buzzsaaw's Avatar
Buzzsaaw Buzzsaaw is offline
Smile Tube Testers tester
Hi folks,
What is a " Copper Cap Tube Tester "?
from Here:
http://cgi.ebay.com/ws/eBayISAPI.dll...253D&viewitem=
Been trying to run down those places he tells about but I just don't find it.
Buzz
______________________
Buzzsaaw
Sunlitedreams.com
Old 04-17-2011, 04:36 PM
JohnHacker1's Avatar
JohnHacker1 JohnHacker1 is offline
Seems like something that was created to test one of the tubes in the tube tester.
Old 04-17-2011, 08:59 PM
It's an dummy tube used to ensure the tester verifies shorts between elements in tubes. As an ex-calibration tech for the Navy, I can say the calibration procedures for testers had you place a decade resistor acrosss pins of several sockets to verify proper short lamp illumination. Someone has just taken this and simplified it, apparently for octal base tubes only. Given most testers have several dozen sockets with varying pinouts, it falls short of completely checking the shorts function.
To fully calibrate a tube tester, we had "standard tubes," shunts, decade resistors, a FET current source, and an RMS voltmeter (to measure incoming line voltage - some use a variac to compensate instead, but measure "average" line voltage rather than RMS as called for.).
TV-7's were easy - it's those blasted TV-2's and cardamatic testers that were a pain. Seventy or more setups for some. Thankfully, they had a three year calibration interval, and were easy to handle on the bench.
Cheers,
USN RET 22YRS (Avionics/Cal)
Old 04-18-2011, 08:11 AM
Buzzsaaw's Avatar
Smile Info
Hi Guys,
Thanks for the help. Sounds good.
That takes the confusion out of this.
Buzz
Buzzsaaw
Sunlitedreams.com
