boost rectifier
hey guys i hate to ask but i will, in a ctc15 the boost rectifier would that be the hv rectifier tube 3a3? i am so used to a rectifier being a diode and not realizing it could be a tube.
Looks like the B+ boost is provided by the 6DW4 damper diode, the 3A3 is the HV rectifier diode.
jr |
thanks, im just so used to the newer stuff.
Man! a CTC-15 is the newer stuff!
![]() jr |
If I'm reading your question correct the Boost Rectifier is not the HV Rectifier/3A3 Tube. There is also a high voltage (generated by the flyback transformer) and it is a boosted voltage, ala B+ Boost voltage. Some sets will have a B+ Boost diode which is solid state and there may be one on your 15. Your chassis also has a solid state Focus Rectifier.
| Audiokarma |
any other rectifiers in this chassis as far as solid state i found, 2 diodes right off the power transformer, 1 in the horiz which is a dual, and a selenium in the convergence board.
