Old 05-02-2011, 10:13 AM
TV-collector's Avatar
TV-collector TV-collector is offline
Barberpool-Question
Hi to everyone,
I need a fine scan of the Philco Predicta barberpool manuals.
It has to be a 9 L 37, the set has no real tags like european sets.
My line transformer went south, so I am planning to change the CRT
(which also has to be a troublemaker), the line transformer, and the yoke.
I should decide to use Philips material, AW 53-88.
Maybe the knack is a little longer, so I have to add some distance washers.
Maybe I have to make some changes in the schematic of the set.
Anyone experience with that?
Until now I didn`t check the datas of both CRTs.
All inputs are welcome!
Best regards,
TV-Collector
Old 05-02-2011, 11:22 AM
You can order the Sams manual from http://www.samswebsite.com/ . It is Sams item #113111; Set 439, Folder 1.
Old 05-02-2011, 10:46 PM
Penthode's Avatar
Penthode Penthode is offline
Curious: Barberpool? Never heard of a Barberpool before.
A Barberpole was a tall, pedestal type structure generally posted outside to locate a Barbershop.
Wasn't the Philco Predicta likened after a Barberpole?
Old 05-02-2011, 11:10 PM
The ETF has Schematics for the Holiday, Tandem and the Princess, I'm not sure if any of those have a chassis similar to the Barberpole (Philco called it the Pedestal) or not.
Click here: http://www.earlytelevision.org/tv_sc..._diagrams.html
Old 05-03-2011, 12:41 AM
the holiday uses the same chassis , the other later 21" barberpole used the 17" chassis with a 5u4 too
mike
Old 05-03-2011, 09:34 AM
Thanks for giving this fine source!
Best regards from Germany!
