Old 05-05-2011, 12:42 AM
Panasonic CT-32SL13G saved
I was walking through my neighborhood this evening and spied this set sitting in an alley.
It seemed the previous owner took care not to damage it when throwing it out. I headed home to get my car and rounded up a friend to help carry it.
I figured it would make a nice upgrade to my 12 year old 27" Trinitron. It's pretty heavy but we were able to handle it.
I unloaded it in the garage and power it up. After a loud bzaaang (degausser I assume), I was treated to some nice snow
That was enough to motivate us to carry it up the stairs to my place. It wasn't easy, but we made it eventually I'm really gonna feel it tomorrow. I found a users manual online, but they don't specify the weight.
Anyone know what it might be ? I'm not sure my old stand can handle it
We still have a few local analog broadcasts so I fumbled my way through the menu and switch from cable to antenna mode. Then hooked up an old pair of rabbit ears and autoscanned.
It locked in on this Korean language station. The picture and sound are great. The only problem so far is a discoloration in the lower right. I hope it just needs a little degaussing.
Anyone have an opinion on this set ?
Old 05-05-2011, 05:27 AM
I have a 34WX54J I got the same way. Similar set also very nice. We also get arirang Korean tv channel here ota, One day they featured a korean town not too far from us with an award winning restaurant - we are going one day !
Old 05-05-2011, 06:57 AM
You wonder what made somebody chuck a mostly pretty good set like that in the 1st place...Oh, well, their loss, your gain...Enjoy !
Old 05-05-2011, 10:37 AM
Probably because it weighs something like 200 lbs ! A lot of folks move on May 1st in my neighborhood and lots of goodies get left behind
It's a real bonanza for the scavengers! That's how I got my microwave and office chair too. Didn't look like either had ever been used
I discovered a "geomagnetic correction" menu item. I'll play around with that and see if the discolored spot changes.
Old 05-05-2011, 10:43 AM
I fixed a set like that (blown fuse) for a customer. I must say that it was a very well made TV, especially considering it was from the early 2000's. Panasonic and Sony are probably the only two "late" brands of CRT sets that are built decent.
Old 05-05-2011, 01:18 PM
sampson159's Avatar
sampson159
nice score!looks sharp and why would anyone through this out?my friend has a 32 flat sanyo from 2006 that has the best picture on a crt i ve seen.perfect!a walmart set to boot.my sister has the same set and it doesnt look near as good.i guess the last few years of crt sets were hit and miss
Old 05-05-2011, 04:58 PM
I've seen relatively new ones at the curb here as well.
Old 05-05-2011, 10:40 PM
Geomagnetic correction did the trick
Old 05-06-2011, 08:37 AM
That set is Panasonic's "Tau" series, which was top of the line for that year. It was direct competion for the Sony Trinitron.
Old 05-06-2011, 02:37 PM
holmesuser01's Avatar
I like that Geomagnetic Correction system.
Old 02-08-2013, 12:08 PM
Ugh. After almost two years of flawless service, it died this morning. I turned it on, heard the usual internal click, then nothing. I'm thinking there might be a circuit breaker reset on the back somewhere ? Problem right now is that there's no way I can move it by myself to take a look
Old 02-08-2013, 12:20 PM
I haven't heard of too many late model sets, that used a circuit breaker.
Probably an electrolytic dried out in the voltage regulator circuit.
First thing I would do is plug it in a variac and start it at a lower input voltage. Like 105 volts and see what happens.
Old 02-08-2013, 12:25 PM
Oh, I should have mentioned that I don't get the click anymore - just that once. It's totally dead now.
I did a little google search on this model and it sounds like there's a fuse on the power supply that's likely blown. Probably due to a bad electrolytic as you suggested.
Old 02-08-2013, 12:57 PM
I always look at the way the fuse looks. If it's all black inside, usually means a nasty fault.
Old 02-08-2013, 03:05 PM
I'm getting very frustrated try to get this set apart! How the heck do you disconnect the CRT board from the main PCB / flyback ?
I thought maybe the HV wires pulled out of the flyback but that doesn't appear to be the case.
