Old 05-20-2011, 02:32 PM
HadYourPhil's Avatar
HadYourPhil HadYourPhil is offline
Paint for test gear case
I have an old signal strength meter that has grey crackle paint on it. Case is aluminum, BTW. Anyone know where I could find that or similar paint??
"We improve things by making them worse"
Old 05-20-2011, 06:01 PM
bob91343 bob91343 is offline
Try this:
http://www.amazon.com/Vht-Paint-Sp20.../dp/B004C11JCQ
That's gray wrinkle paint. Some units used a finish called gray hammertone.
Old 05-20-2011, 06:21 PM
Is it in need of repainting, or just dull? I've had good luck restoring some old boatanchor-style test equipment by spraying WD40 on the finish and wiping it down with a cotton cloth. GE Ham news suggests wiping down with Mineral Oil or 20W/30W oil.
I've also repainted with blue hammertone paint from ACE hardware with outstanding results. 2 light coats, followed by baking in the oven (an old surplus oven used to bake out moisture in aircraft instruments) at 170 degrees for 15 minutes - hard as a rock, and glossy to boot.
Cheers,
USN RET 22YRS (Avionics/Cal)
Old 05-21-2011, 09:35 AM
Unfortunately the bob91343 link says "out of stock".
It amazes me to see the number of people who are searching for this product which no one seems to make. I would not be able to do the baking trick referred to above.
The cabinet needs repainting.
Old 05-21-2011, 05:36 PM
Plastikote 217 Black Wrinkle finish is available nationwide at Carquest Auto Parts places, and at Northern Tool and Supply. I guess you'd paint black, and then give it a light coat of gray to prevent finish "build"
Krylon makes it too - 3317 Black Wrinkle paint. Our PepBoys carries wrinkle and hammertone finishes, as do most "DoIt" franchise hardware stores.
There's also spray "grit" paint that applies a non-skid surface, haven't tried that stuff, but would like it for a stainless bumper I have on my truck.
Cheers,
Old 05-23-2011, 06:02 PM
I had suggestions to do as F-K has suggested and that seems to be the only realistic solution. So, tomorrow I'll paint shop!
