Hellllp! with my roundie!!
Okay, so I've been using my Zenith roundie (Laura) as my daily watcher for months now with no problems.
Last night, the picture started "undulating." Picture the way a flag moves in the wind, but the undulation moves up the screen rather than across. What would cause this? Please don't tell me Laura's days are numbered!
Veg:
From your description it sounds like the filter caps in the B+ supply. Does the picture pull in a bit from the sides when the wavy pettern goes through that spot? Steve |
I don't know if any of the round sets used a degaussing coil, but in several rectangular Zeniths I've seen the degaussing thermistor has gone open and caused a very wavy picture.
Filter caps though are the more likely suspect. |
I changed only the filters that needed to be changed. However, my NOS supply was from 1980!!! Perhaps one of my 24 year old capacitors is now defective. In zenith, a very common value is 80uF@450volt. Thats what I put in there, 2 of them if I remember correctly.
If the degausing thermistor was a problem, you would also see purple and green colors in the waving (as the magnet is not turning off, its always on) From your description, the caps are bad. You can buy caps from mouser.com they are around $6 a peice. Not too many stores carry caps up in the 450 volt range. most dont stock anything after 100volt. Before you buy caps, bridge over the ones I put in one at a time with a similar value cap and see if the problem goes away. If so, thats the bad cap.
I tolerate the present by living in the past... To see drh4683's photo page, click here To see drh4683's youtube page, click here Last edited by drh4683; 09-24-2004 at 04:32 PM. |
Also remember to change all caps in a can if any one in the can is bad...sometimes only one may appear bad, but the problem that messed up one of the caps can eventually affect the others.
| Audiokarma |
Thanks for the help, gentlemen!
I ordered two of the 450V 80uf caps from Mouser today. Ugh. I thought I was finished with all this cap replacement and soldering and stuff once I got my Heathkit running. No such luck! Gotta do this, though. My Zenith roundie is my daily watcher and I've not been using it so I don't break it. I'm missing all my favorite shows!* (No cable in the den where my Heathkit is. Should do something about that...) Douggie: Can you give me a hint about where I should be looking for the caps in question? I'd like to only pull the set away from the wall once and get the job done in one fell swoop. Hmmm. Maybe I should look at this as an opportunity. An opportunity to buy one of those "cold heat" soldering irons! Bob * Currently How Clean Is Your House? and In a Fix.
I originally got that set from John Horvath (jshorvath65) about 2 years ago, maybe 3? Anyway, there originally was a metal grille beneath the set and was removed and never put back. A window screen was stapled underneath to takes its place by someone else, but you will need to pull that screen off and you will see 2 large blue capacitors. Theres nothing else like it in there, they will jump out at you, they are about 1"diameter by 3" long. When you get the new caps, just jump the leads over each cap while the set is on and see what happens to the pic. Be very careful as the wrong move will give you a nice 400volt blast of energy which will throw your hand back faster than you could ever immagine! A 400 volt B+ zap is much worse than a 25KV zap! After you jump the new cap, short the leads of the new cap together using the shaft of a screwdriver, or some other metalic object that will allow both cap leads to touch at the same time (fork, etc) to drain the voltage of the cap. You will see a blue spark and a loud snap sound. This indicates that the cap voltage is drained, however you should do that about 2 or 3 times as you will not totally drain the cap in one shot. Do this after everytime you jump the cap over one of the caps in the set.
Since the set will be on its top (so you can work beneath it) you will notice the purity will look very bad, this is no concern and will be back to normal once the set is back in its normal position again. You wont need to play with convergence or anything like that. |
I'll post a message right before I attempt this operation. If you don't hear anything from me for a while, send flowers
Well, veg-o-matic (the village idiot) strikes again.
A while back I got the first of the two new caps installed, which didn't fix my "flag waving" problem but I didn't expect it to, since I still had another to replace. So I finally got around to replacing the second filter cap. Had my set upside down so I could work on it. Jumpered the new cap in place and looked to see if it made a difference. The picture looked a little better, so I soldered it in place (thinking "Lookit me! I'm just like Doug!") and hoisted the beast right-side up again. Now it looks like crap! I swear the rippling is even worse than before! What does this mean? Do I have more caps to replace? And how the heck does one replace one of those "can" caps with the multiple parts? That's where the filters are, right? Am I going to have to break down and buy the schematic for this and try to bluff my way through understanding it? Or is it merely a matter of adjusting something (IhopeIhope)? "Now that the caps are replaced, you just have to adjust the frammis coil until the vertical synchronization locks in with the horizontal output nebulizer." Not that I'm holding out any hope... And guess what? The Heathkit in my den is starting to show the same problem! veg
| Audiokarma |
Also make sure the old cap's positive lead is disconnected from the circuit. If the old cap is hooked up electrically it will cause trouble. I mount a terminal strip under the chassis and hook up the single value replacement caps to it.
The ESR meter is a good tool to find bad electrolytics...our meter only cost $12 or so. |
While your problem sounds a lot like bad filter caps, there is one thing I would check first. The bending and weaving can also be caused by a heater to cathode short in a tube. This could explain why the picture got worse when you turned the set back over. I would start with the tubes in the RF and IF sections, but I would quickly check all the tubes, since a short in almost any tube could cause this symptom to some extent. Also check all ground connections.
Good luck, have fun Bill R |
without seeing the set in person it's hard to tell, but it sounds like a bad filter cap. If it got worse I would suspect the new cap is the wrong value or it's not installed correctly. I would double check everything on the caps before I started digging into other areas.
Just for yucks - doublecheck the AGC adjustment - I know most of my sets do that when the AGC's set wrong...
Bill R. has a good point. HK shorts can cause some wierdo problems especially in the tuner. Sometimes in the IF stages too.
But do check those filter caps. Since those caps you replaced failed to correct the job, one of the other(s) filter caps may very well be causing this flag waving symptom. Since bridgeing over the caps revealed nothing, it tells me one of the caps is leaking badly. Bridging over a leaky cap wont tell you anything, only when a cap is open, or changed in value will that work. (I originally suspected either open or changed value cap) What you will need to do cut (or desolder) one lead at a time to each leg of the filter caps. Then use your VTVM (or whatever kind of meter you have) and set it to RX1 and test from ground to the cap. IF the needle goes up and or barely goes down, the cap is leaky and is defective. Reverse the leads and check again to see if you get the same results. If no meter movement in RX1 mode, the cap is probably good. Set the meter to RX100 and check, A good cap will cause the meter to rise and fall rather quickly, and when you reverse the leads, the meter needle will peak off the scale and fall back down. If you find a bad cap in a can, you can easily recap. in this case its best to recap all the filters since you are watching the set all the time. If you order individual axial caps, twist all the negative leads together and then solder that to a ground lug (the lug that holds the original filter can to the chassis is good ground terminal) then just cut the wires to the original filter can and solder those wires to the corresponding values of the new cap. Thats it. Give the test a try though and tell us what you come up with, then we will go from there. Good luck-Doug
I tolerate the present by living in the past... To see drh4683's photo page, click here To see drh4683's youtube page, click here Last edited by drh4683; 11-29-2004 at 06:01 PM. |
| Audiokarma |
