Old 06-16-2011, 08:45 AM
Buzzsaaw's Avatar
Buzzsaaw Buzzsaaw is offline
Smile erla and what is it?
Hi Folks,
A friend gave me this old radio. The dial says ERLA and the chassis says 46A 4800E. Label says 46ACE-140-E.
I see the unit is licensed by Hazeltine Corp. (on the label)
Help me out so I can find a Schematic for this nice little radio.
Thanks for the help,
Buzz
______________________
Buzzsaaw
Sunlitedreams.com
Old 06-16-2011, 09:29 AM
Looks to be a mid Thirties console...
Old 06-16-2011, 09:53 AM
Reece's Avatar
Reece Reece is offline
Erla was an old radio company from the twenties that blended into Sentinel in the thirties. I believe your set's schematic is the following indicated as model 46A in the Sentinel listing from "pre-1938." Your sticker on the radio back says made in plant "S" which tastes like Sentinel. It's an 8-tube set with tuning eye, and from what I can see on your pictures, the tube lineup looks right compared to the tube layout on the schematic. Have a look and compare to your radio.
http://www.nostalgiaair.org/PagesByM...7/M0018207.pdf
Reece
Old 06-16-2011, 11:15 AM
Buzzsaaw's Avatar
Wink Sentinel
Thanks guys,
It does look real close. I wonder why there "ERLA" name isn't listed in the Schematic database web sites?
This should get me started soon as I get done with two other little projects.
The case sure is well built and sturdy. The speaker looks like brand new. Do you suppose it's been replaced?
Buzz
Buzzsaaw
Sunlitedreams.com
Old 06-16-2011, 12:19 PM
bob91343 bob91343 is offline
The diagram shows a three band radio when there are only two bands on the dial. As for the speaker there seem to be too many wires going to it. Four wires to the field coil? If so, that would mean two field coils, like a hum bucking coil. Unlikely an exact replacement would be available any time in the recent past.
An interesting puzzle. What does it say on the green tag?
Old 06-16-2011, 01:05 PM
teevee's Avatar
teevee teevee is offline
4 wires going to the speaker (and output transformer peeking out from the bottom). That would jive with what the schematic shows. One from the rect to the speaker field, one coming from the speaker field back to the set (and the center tap of the OPT) and the 2 plate leads. The wire between the speaker cable and green tag appears is just hanging there, not connected to the speaker. I'd suspect that was the antenna lead, with the black wire (green tag) being ground.
Old 06-16-2011, 01:28 PM
Nice looking cabinet. once you get it working and refinish it you will have a real show room piece.
Old 06-16-2011, 03:45 PM
Buzzsaaw's Avatar
Smile bucky humbucky
Hi guys and thanks for all the help,
I count the 4 wires on the schematic too. And to satisfy Bob's statement about a Guitar Humbucker, the drawing shows the "bucking Coil" right in the speaker area.
I haven't opened it up yet to look but I see, on the schematic, the 12 and 16 mfd caps in the rectifier Ckt. Those might be the type housed in a Bakelite tube. (?) As Banderson shows in his famous videos on U-Doob. That's Cool.. I'll have to find some wax to re-do those correctly as he shows.
Buzz
Buzzsaaw
Sunlitedreams.com
Old 06-16-2011, 08:59 PM
teevee's Avatar
Look at pics 4 and 5. The aluminum cylinders between the power transformer and tuning cap are the filter caps. the 16uF minus goes directly to ground, the 12uF does not. (look for insulating rings around the bottom)
Old 06-16-2011, 09:28 PM
That may be the newest set I've seen with the ERLA name. I believe this was "brand-engineered" and likely available under a few aliases. The shape of that dial shows up on a few other minor brands from the late 30s.
I like it!
Old 06-16-2011, 10:02 PM
I think you'll be well-pleased w/it when you get it percolatin' again...(grin)
Old 06-18-2011, 11:44 AM
Buzzsaaw's Avatar
Smile 3 band radio
It's the Weekend!...
I was looking at the drawing and the dial ... 3 band? If you look just around the area of the ERLA name and in the same yellow ink..you'll see the 5.8 to 18.1 mhz band.
Buzz
Buzzsaaw
Sunlitedreams.com
Old 06-19-2011, 10:59 AM
Reece's Avatar
One of the posts above said that the wiring diagram that I pointed out shows a three-band radio, but your dial shows two bands. The diagram is the closest one I found to your radio. Yours is probably a variant where they eliminated the less interesting first short wave band.
Reece
Old 06-19-2011, 12:06 PM
Buzzsaaw's Avatar
Smile 3 bands..
Reece.. if you look close to the dial picture, the radio does have 3 bands.. as mentioned in my last post.
Buzz
Buzzsaaw
Sunlitedreams.com
Old 06-26-2011, 07:44 PM
dimbulb dimbulb is offline
Hi! ERLA stands for Electrical Research Labs. They were a radio mfg. located in Chicago. Schematics can be found on Nostalgia Air under that name. The reason I know this is that I just acquired a 1930's ERLA cathedral yesterday. Interestingly, it has a Hammond clock mounted within the area of the speaker cone making it one of the first clock-radios!!
