Old 07-11-2011, 10:01 PM
darklife's Avatar
darklife darklife is offline
Modulating Madness
78's from my Grandmas
My grandma passed away a few months ago. After going through her stuff I found a small collection of 78s.
I doubt they are worth much but honestly I don't know. If anything I'd just love to play them on an actual record player and to me that would be worth more than the small sum of money I would probably get out of them.
These shellacs were found in her sheds on her property. Full of the usual grime and age.
I found many sleeves asking to buy war bonds...
Here is a case I found of regular old 78s all in excellent condition..
As you can see many are missing the paper sleeves but the records themselves are in really good shape.
I don't have a way to play them though so I can't honestly judge that they are good to go, but they look smooth and rather good given their age.
I don't plan to sell them soon since I figure they are worth almost nothing. Please tell me if I am wrong. I looked up a few records in worse condition than mine on ebay and they were going for 10-30$ a pop.
I would enjoy hearing them first before I sold them, however I am open to learning about these.
Sorry if this is mediocre to you all as you probably come across these all the time, but to me they are special knowing how they made it through our family all this time.
I do know that it doesn't matter though for collector value. So can someone give me a judgement on value for old cast away 78s and what I can expect?
I just hope they aren't worth less than scrap metal after I find a way to play them and record them to a new medium.
Thanks.
Old 07-12-2011, 01:19 AM
Some 78's are worth some money and others would be doing good to bring fifty cents/each. The main ones that are worth a few dollars and up are blues, R&B, some country, and '50's rock/roll 78's. If they were mine, I'd probably keep them if they belonged to my Grandmother.
As far as playback, the first piece of advice I'll give you is DON'T BUY one of these current production Corsley (or other brand) record players. These are cheap made Chinese junk and even though some of them have 78 rpm speed, they do not come with the proper 78 rpm needle. A stereo LP or 45 requires a .7 mil needle. The much wider groove 78 requires a 3 mil needle. If a 78 is played with an LP needle, the playback will be very noisy and record/stylus damage may result.
For a quick, fairly inexpensive solution; I'd look for an old Newcomb, Audiotronics, or Califone classroom record player. I prefer the older tube models from the '50's and '60's, but any of them with 78 rpm speed should work for you. These models have a flip over style needle with an LP needle on one side and a 78 needle on the other; however, some newer needles have dual LP tips. If in doubt, replace the needle with a known 3 mil 78 needle. You can also play modern LP's and 45's on these classroom players; but, I wouldn't recommend playing a mint or valuable LP/45 on one because the tonearm will be heavy and will wear the record quicker. 78's, however, are a different story. The tonearm on a classroom player is gentle in comparison to what these 78's were originally played on and the classroom palyer shouldn't hurt a 78. For this type of player; check ebay, the local flea market, or your next school board surplus auction.
Another more costly option would be to purchase a turntable with 78 rpm speed, a stereo receiver or amp, speakers, and the proper cartridge for playing 78's. This method can be costly; but, may be worth it if you get into record collecting.
Old 07-12-2011, 01:32 AM
bob91343 bob91343 is offline
Where are you? I have 78 equipment and could play them.
The valuable records are the truly rare ones. I have one that is ODJB (Original Dixieland Jazz Band) recorded about 1919. The first jazz record was either 1917 or 1918. I also have some commercials, you know, sales pitches for events like movies or stock car races. It appears the ones you have are more ordinary than that but why not post the titles and artists? What was your grandmother's time frame?
Old 08-23-2011, 08:42 AM
DougMac's Avatar
DougMac DougMac is offline
Are you still here?
You mentioned that the records are dirty and without sleeves. They shouldn't be played before they are cleaned.
Take a paint brush with moderately stiff bristles and sweep away as much loose dirt as possible. Mix up a pan of tepid water with Dawn. Don't use a substitute, use Dawn. Take another brush and work the solution into the grooves following them. Rinse. Take a paint pad wetted with the solution and follow the grooves. Rinse again. Use a soft cloth to pat dry. Place in a wooden dish rack and allow to dry. Don't play the records for at least 24 hours.
Try to keep the labels as dry as possible. Columbia red labels will bleed. In addition, some RCA Victor 78's made in the late '40's or early '50's used a water soluble ink. Get the label wet and all the print washes off!
Give us a list of a few.
Old 05-14-2024, 12:33 AM
Dude111 Dude111 is offline
Analogue is Awesome
My aunt recently moved from a house they had in the family 50+ years.. My grandma and grandpa passed long ago......... They had about 11 78s and my aunt gave me them.....
1 was broken but I was amazed the rest were in good shape.... I like them all!!
Old 05-14-2024, 02:18 PM
Hawkwind's Avatar
Hawkwind Hawkwind is offline
TV DXer...
I played back 78s, years ago on a Garrard Zero 92. Used a Shure or Pickering cartridge with a 78 stylus. I shorted out the Stereo signal to lower surface noise. They sounded pretty good. Columbia 78s from the Teens were recorded at 80 RPMs. Dubbed those to cassette and played on a deck with a pitch control. A Zero 100 would have been better because it has a pitch control, but I used what I got.
Trivia: the first Million selling record was, "Carry Me Back to Old Virginny" by Alma Gluck, and I had a copy in the "70s...
Old 05-14-2024, 03:34 PM
Analogue is Awesome
I have a couple 80rpms..... Those are the thick edison records
Old 05-14-2024, 04:43 PM
Phil Phil is offline
Just a note on a related subject: PLEASE DON"T PLAY DIAMOND DISCS on any machine designed for 78's. It will destroy them in one pass and you will hear nothing! These are recorded vertically and designed to be played only with a diamond stylus of the proper profile to fit the groove. The surface is a coating more akin to lacquer than anything else, lower noise and long life if played properly but not designed to endure the indignity of being played with a steel (!?!) "needle". The reason I bring it up is because I've bought several of these on Ebay that were destroyed by the seller trying to listen to them on a "Victrola".
Old 05-14-2024, 08:17 PM
The Edison discs can be safely played on a stereo cartridge (light tracking force is recommended). Any mono playback device that isn't a Edison diamond disc phono should NEVER be used to play a Edison diamond disc.
I also worked with what I have to have some 78 phonos. One of the more interesting projects was taking my late 70s Philips GA212 2-speed with pitch control and making it 78 RPM capable. On the surface it's only needed a extra resistor and a switch to work but I wanted a fancier implementation that didn't require drilling a new hole in the case so I came up with a more extensive control modification that I did a YouTube video on.
Old 05-14-2024, 09:22 PM
Analogue is Awesome
I have only listend to my 78s on my mono player.... I havent played the thick edisons.. I only have played those on my stereo crosley player....
I didnt know a Mono cartridge might hurt a edison record,is that because its so close to the record??
Old 05-15-2024, 01:55 PM
You didn't read or understand what was posted earlier did you...
Edison diamond discs were recorded with vertical audio modulation (stylus moves up and down) in the groove. All NON-edison mono players used lateral audio modulation (stylus moves side to side). A lateral pickup can not pickup vertical audio and vice versa.
Stereo pickups are 45-45 stereo the right groove is audio modulated at a 45 degree angle above lateral and the left groove is modulated at a 45 degree angle above lateral. Consequently the left and right modulation are at a 90 degree angle to each other* which prevents cross talk between left and right (similar to how lateral and vertical grooves are at a 90 degree angle to each other and one type cart can't play the other type record)...Also because of this angle a stereo cartridge stylus must be able to move easily both vertically and laterally.
Mono cartridges (especially those made before stereo came out in 1958) usually have poor vertical compliance so if you play a record with vertical modulation components to it such as an Edison diamond disc or a stereo record a mono cartridge (the stylus of which doesn't like to move vertically) the styli will literally erase the vertical modulated music by scraping it off...Some older stereo LPs have warnings on the jacket and or label stating that the record will be damaged if played on mono equipment for this exact reason.
Also if you wire the stereo channels together in the correct manner you can make a stereo cartridge act like a lateral mono or vertical mono cartridge. (Useful when playing a mono record as the unmodulated axis contains only record scratch noise so canceling the unmodulated axis cancells a fair portion of record noise.)
* 2 signals on the same medium encoded at 90 degrees separation to each other is a very useful concept color television uses Quadrature Amplitude Modulation to pack 2 color difference signals into a single chroma signal that's more bandwidth efficient and easier to hide mixing into the monochrome signal...The quadrature in this case meaning 2 radio frequency carriers of the same frequency with a 90 degre phase difference between them each carrying a different modulation signal payload....the 90 degree phase shift prevents crosstalk which keeps the 2 modulation payloads seperate and distinct from each other.
Old 05-15-2024, 03:20 PM
Hawkwind's Avatar
TV DXer...
I was under the impression that the flat thick Edison disks were around 60RPM. Also, that they have a wider frequency response. I haven't thought about Edison disks in 50+ years...
Old 05-15-2024, 03:42 PM
Analogue is Awesome
Thank you Electronic M,I read your reply carefully.,,
It makes me worried of playing any of my records on my mono player.. (Which I have been and they seem ok but I dont want to hurt them)
Thank you!!
Old 05-22-2024, 07:33 AM
DavGoodlin's Avatar
Motorola Minion
I have never seen a diamond disc, but sure will look after this thread. I have seen shellac records break when dropping on a
period-correct changer that was made to play them, please be careful.
My go-to setup for playing 78s is any Zenith, Magnavox, VM, RCA, Garrard, BSR or similar vintage record changer with a flip-over stylus.
Most of the 3 mil are sapphire for 78s. MG and LP are the same, most have a "78" side, confirm but don't assume.
45 rpm records are best on a player designed just for them, using the adapter on a record changer is less preferred.
Cartridges are another subject but assume any player can be fitted with a new/old stock cart and the stylus can be selected.
If the cartridge is OK, a stylus is probably available no matter how old it is. Cartridge compliances shrink/harden with age even NOS carts, sounding dull and this is why there is a surplus of stylii to fit them.
There is a weekly record collector swap meet in my area, I saw folks walking around with portable players to "sample" discs.
I heard no music (hard rule?) saw nobody selling players, so I never went back. Not my bag, just play and enjoy!
-Dave G
