Old 09-29-2011, 03:36 PM
relaximus's Avatar
relaximus relaximus is offline
Consoles 'Я' Us
Grundig 2540U Antenna
I little help please, I've just acquired this Grundig 2540U and I'm trying to figure out an external antenna. Any suggestions as to what might go into these holes? I also need to replace the dial light(s). I haven't pulled the chassis yet, but any ideas on what they might be and how difficult their replacement is? I was really wanting a Majestic model, but this one was just too nice (and cheap) to pass up.
Thanks!
Dave
Relax and
Fisher, Grundig, Motorola & Magnavox Consoles | Dahlquist DQ-30 | DCM TimeWindow 3 | PSB Stratus Gold i | RtR II-F | Klipsch KG-4 | KLH 6 & System 20 | Nakamichi PA-7 | B&K Monoblocks | Outlaw Audio 950 | Carver MXR-130 | Pioneer SX-1250 | Sansui 9090DB
Old 09-29-2011, 03:53 PM
Someone knows for sure, but I believe the two labeled "FM antenna 240 ohms" can be connected to a twin lead folded dipole antenna, and the two on the right labeled "GND ANT" can be used for ground and a long wire antenna for AM and SW.
Old 09-29-2011, 04:18 PM
Komet's Avatar
Komet Komet is offline
Nice radio, I have the models 4088 and 5088 (Konzertgerät)
The replacement of the bulb should not be difficult. For the antennas, I confirm the previous post :-)
Old 09-29-2011, 04:29 PM
relaximus's Avatar
Consoles 'Я' Us
Thanks guys! I've wanted one of these wood-cased, German radios ever since I got my first Grundig console. I think they are just a marvel of engineering and I'm hoping to begin begin a radio collection starting with this one. I can't wait to dig into this thing, I am excited!
Dave
Relax and
Old 09-29-2011, 04:55 PM
Banana plugs fit those connectors nicely and are convienently caried by radio shack.
Old 09-29-2011, 05:03 PM
Komet's Avatar
Dave
Yeah, I agree with you. In addition to my two Grundig, I have a Loewe-Opta 2791W Venus Luxus and a Graetz Sinfonia 522
Old 09-29-2011, 05:08 PM
relaximus's Avatar
Consoles 'Я' Us
Okay you table-radio gurus, anything that I should be aware of prior to attempting to extract the chassis from this little beasty? It looks pretty straight-forward (if I can get the damn knobs off!). This thing appears to have the same e-stat tweeters as my Grundig console!
Dave
Relax and
Old 09-29-2011, 05:18 PM
Komet's Avatar
The only advice I can give you is to be careful when you remove the screws that lock the chassis, be careful that does not move during this operation otherwise you break the glass
Marco
Old 09-29-2011, 05:24 PM
relaximus's Avatar
Consoles 'Я' Us
Thanks Marco! Advise taken and will be heeded. Any ideas for getting these stupid knobs off? They pulled off fairly easily on my Grundig console, but these don't want to budge.
Dave
Relax and
Old 09-29-2011, 05:30 PM
Komet's Avatar
The knobs haven't a small screw? With my knobs I never had problems.
Great console!!! What is the model??
Marco
Old 09-29-2011, 06:09 PM
relaximus's Avatar
Consoles 'Я' Us
It's a 1960 Grundig Majestic SO190U.
Dave
Relax and
Old 09-29-2011, 07:29 PM
Some sets don't need the knobs removed because the dial glass is attached to the chassis on a fair precentage european sets, and it is a safe bet that that is the case with your set. Try unbolting the chassis and GENTLY pulling it back, and if it slides easily and the glass moves in complete unison with the chassis then the glass is probably attached to the chassis rather than the cabinet. I beileve some european companies used set screws on knobs so look out for those.
Good luck.
Old 09-30-2011, 03:36 PM
relaximus's Avatar
Consoles 'Я' Us
Thanks for the tips everyone. Now would anyone have a schematic for this radio? A thorough web search has turned up absolutely nothing for this model.
Thanks again!
Dave
Relax and
Old 10-08-2011, 01:59 PM
relaximus's Avatar
Consoles 'Я' Us
Could anyone recommend a good restoration shop in my area (Western CT)?
Thanks!
Dave
Relax and
