Old 10-17-2011, 07:50 AM
rcafan rcafan is offline
CT100 info
Has any body replaced the selenium rectifier in the
CT100 with diodes?Info appreciated.
What's the name of the parts house in Pennsylvania
That carries a great deal of old stuff. I think it
Starts with an M
Old 10-17-2011, 10:14 AM
miniman82's Avatar
First Light: 1952-2011
Why, have they gone bad?
You're thinking of http://www.surplussales.com/
Evolution...
Old 10-17-2011, 10:28 AM
grimer's Avatar
grimer grimer is offline
Starts with an M
Moyers -----> http://www.moyerelectronics.com/Depa...-TV-Parts.aspx
Old 10-17-2011, 12:03 PM
This previous thread discusses the selenium issue.
Looks like the votes are about evenly split between replace vs. leave alone. FWIW, the previous owner of my CT-100 did replace the seleniums. If you replace 'em, disconnect the old unit completely (that is, don't wire the diode in parallel).
Regards,
Phil's Old Radios
Old 10-17-2011, 12:51 PM
Penthode's Avatar
Penthode Penthode is offline
Why not? The seleniums when they go, don't they simply open (go high resistance)?
Old 10-17-2011, 01:06 PM
Some times they short and relese toxic selenium gas.
Old 10-17-2011, 05:42 PM
reeferman's Avatar
Believe it. I've experienced shorted selenium(s) clearing out a shop.
Old 10-17-2011, 06:18 PM
They develop reverse leakage also.
Old 10-17-2011, 11:33 PM
I had once case where a selenium smoked real bad, and the only thing that went open was the windows, and they stayed open for about a week
Old 10-19-2011, 10:56 AM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
If you use them, fuse them.
I've had good luck with old test equipment and radios that use them, but not in TV's where they see higher loads.
