Old 10-26-2011, 12:26 AM
Billzimm2 Billzimm2 is offline
Admiral 22x12 Questions
Hi guys,
I just picked up a Admiral 22X12 Television for $40 and I have a couple of questions.
Is there any risk of shock from the CRT? I have read that some if not all CRT's can carry a high voltage charge that could be lethal even when the TV set is unplugged. If this true?
Also does anyone know where I can find a schematic for this set?
Is this one of the easier sets to work on?
I've worked on several old radios before and happened across this one and thought I could make this a good project to get running again. Any help is greatly appreciated.
Thanks,
Bill
Old 10-26-2011, 01:05 AM
miniman82's Avatar
First Light: 1952-2011
A zap from an unpowered tube won't kill you, but it'll cause a few curse words. lol
Bob should be along shortly, he has a video on this exact set.
Evolution...
Old 10-26-2011, 05:44 AM
earlyfilm's Avatar
Eternal Member
Originally Posted by Billzimm2 View Post
Hi guys,
I just picked up a Admiral 22X12 Television for $40 l
Bill,
If you want to pay a bunch for a schematic, go to ePray.
For a free schematic, go to:
http://www.earlytelevision.org/tv_sc..._diagrams.html
and slide down to Admiral cross reference chart and you will see that the 22X12 uses the 20Z1 Chassis, on which they have both the Sams and Ryder versions available for free download.
Don't worry about the cabinet pictures not matching your set.
As a matter of fact, if you haven't been there, there is more old TV history on http://www.earlytelevision.org than you can read in a year!
The set that I graduated from radio servicing to TV servicing was a similar Admiral model that I bought from a junk store for $10. However that was in about 1955, and if a shock from the HV would kill you, I would not be writing this. However, always keep one hand in your pocket while poking about inside these babies and make sure that you are not grounded.
James
Old 10-26-2011, 11:16 AM
Here's a link to that video http://youtu.be/u1r8Us8FsYQ
I haven't restored that specific chassis yet, but I have just done a couple very similar 20X1s. Yes, they're fairly easy to work on as vintage TVs go.
Admiral 20X11: http://www.videokarma.org/showthread.php?t=252263
Admiral 20X12: http://www.videokarma.org/showthread.php?t=252047
Check my YouTube channel for the videos.
Old 10-26-2011, 12:36 PM
Wow, that YouTube video is awesome. Thanks so much. Your YouTube channel is the best ever. I can't seem to pull myself away from watching your videos.
I have to go fix someones computer for them this afternoon, but tonight I plan on starting to clean up the set. I'm sure I will have many more questions for you guys, I really appreciate the help.
The story of how I acquired this set is that I work for a big retailer that you can drop off your old electronics for recycling. Someone dropped this set off and I had to have it. I made a "donation" to one of the our party funds..... I was so lucky that this set just fit in the trunk of my Acura coupe. It is really heavy though, my gf had to help me get it into my apartment. I can't believe someone would recycle this set. Well I will report back with my progress tonight.
Old 10-26-2011, 01:29 PM
Good luck! I found mine locally on craigslist. The owner was seriously planning on making it into a fish tank if he didn't find a buyer.
Old 10-27-2011, 12:16 PM
Reece's Avatar
Reece Reece is offline
Bob, I just spent several hours looking at videos on your website and really enjoyed how thorough they are. Thanks!
Reece
Old 10-27-2011, 11:12 PM
Well I pulled off the back today and it looks very dirty. Got quite a bit of rust on the chassis and the aquadag (black coating) is flaking off the CRT. It does have the original admiral CRT and a few of the tubes have been replaced. I got a few pics of the set and the insides. On a side-note there seems to be an old newspaper in pieces in there. Should be interesting to see when its from. I wonder what I will find underneath. I'm going to remove that chassis next and start cleaning everything. Also whats the best way to clean up all the cobwebs and chassis for now? Just compressed air and a vacuum?
Thanks,
Bill
Old 10-27-2011, 11:48 PM
Kevin Kuehn's Avatar
Workin' Late Again
Hi Bill,
Nice TV.
I always prefer doing the initial cleanup using a small paintbrush and the vacuum method. I personally don't care for all that dust flying around in the air I’m breathing, unless of course I'm outside and upwind. You also need to be very careful using high-pressure air around small coils and open wound transformers. You can literally tear things apart if you’re not careful.
Old 10-28-2011, 01:45 AM
Also that coating that is mostly flaked off the crt, is that something to worry about? will that hinder the operation of the crt? This set might have been stored in a damp environment due to the rust and the flaking of the aquadag.
Old 10-28-2011, 08:56 AM
Workin' Late Again
That dag coating forms one side of a HV capacitor on some sets. You can buy that dag coating in a spray can, but I've never used it. Maybe someone can provide a link to a source. I seem to recall it being related to aircraft usage today.
Old 10-28-2011, 01:15 PM
This set has a 500pF HV doorknob cap right on the HV rectifier tube base to provide some filtering.
I recall seeing a service note that if you have a CRT with no coating a 2nd 500pf cap can be added in parallel.
As for the coating, I've used Aerodag in the past from tedpella.
However, even after multiple heavy coats it has a much higher resistance (more than 10X) than the original coating.
Not sure how much difference that makes.
I recently picked up a can of SlipPlate which I've heard works great, but haven't tried it yet.
You can get it here and many other places: http://www.fastenal.com/web/products...0960950&ucst=t
Old 11-04-2011, 01:03 AM
Sorry for taking so long to get back to you guys. I'm only 22 so I'm busy juggling work and school along with a girlfriend. I did get a chance to take out the chassis tonight. I took a look underneath and it looks to be mostly original. There are a few replacement caps under there, but honestly everything looks to be in decent shape. A few of the caps seem to be either leaky or bulging which doesn't surprise me. I will include some pictures.
Also I can only get the Sam's manual from that site. The Riders link for my chassis just points to that Sam's manual. Does someone have a copy that they downloaded a while back that they wouldn't mind sending me?
On a side note: Bob, I watched your video on this set and mine in fact has that screen on the bottom of the chassis. It isn't attached to the cabinet, but is attached to the bottom of the chassis. If you have any questions, feel free to email me, I am willing to take more pictures if you want me to. You seem very very knowledgeable on these sets and I have spent the last week or so watching all your YouTube videos. Your work is amazing.
Old 11-04-2011, 01:07 AM
Two more pictures: One of the mess left inside of the cabinet and one of the top of the chassis out of the cabinet. Well thats about it for now. I will hopefully have time to clean out the cabinet tomorrow.
Thanks,
Bill
Old 11-04-2011, 04:05 PM
If you haven't already seen them, you might also enjoy my videos on the 20X11 and 20X12 restorations which use the very similar 20X1 chassis.
Thanks for the pictures. This is the first good picture I've ever seen of that metal cover Now I just need to get someone to fabricate a few
I see what you mean about that Riders link. The 20Z1 is actually covered in vol. 5 I believe. I do have a copy but have not scanned it yet.
The Riders for the 20X1 / 20Y1 is pretty darn close so you could start with that.
