Old 12-31-2011, 11:59 AM
stusnyder's Avatar
weird lytics
How do you decipher these? There are no mfd or voltage ratings on them.
Old 12-31-2011, 12:43 PM
I used a reactance calc online, plugged in 900uf at 120hrz came out to 1.5ohm approx, for for voltage I would look at the circuit, that high a uf makes me think its a cathode bypass, so prob low voltage.
Old 12-31-2011, 01:39 PM
Is that cap in a Dumont set? Looks like their part number.
Old 12-31-2011, 02:43 PM
stusnyder's Avatar
Yes it is, and there's a bunch of them. I want to replace them.
Old 12-31-2011, 04:05 PM
mbear2k mbear2k is offline
What's the model/chassis number?
Old 12-31-2011, 10:27 PM
stusnyder's Avatar
Model ra-103 I think the chassis number is 7041-a1
I think I'm going to need a service selector switch, because there's alot of arcing in it. Where's there a good place to get one?
Old 01-02-2012, 11:14 AM
stusnyder's Avatar
It is low voltage, the can has 6vdc marked on it.
Old 01-10-2012, 07:45 PM
Is it possible to identify them from the SAM's or Rider diagrams?
http://www.earlytelevision.org/tv_sc..._diagrams.html
Old 01-10-2012, 08:30 PM
stusnyder's Avatar
Sams does not state it in mfd. Horizontal center control bypass is the ID of it.
Old 01-11-2012, 02:26 PM
Maybe C278?
Which looks like a 100uf at 25v.
This is from the TV Rider on the same page as above.
Old 01-11-2012, 03:45 PM
stusnyder's Avatar
C4, C5, and C6 in sams. I figure a 1000 uf at 25 volts should be ok. Although C6 states 2000 uf.
Old 01-28-2012, 04:06 AM
sharejutt sharejutt is offline
Banned
Thumbs down food combinations
What are some weird but good common food combinations?
