Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > Introductions
Old 01-15-2012, 07:57 PM
cuteorkill's Avatar
cuteorkill cuteorkill is offline
New member from Dunwoody, GA
Hello all! I just joined tonight after a search revealed that there was already a little discussion about a television I offered at auction back in 2009. The same deForest-Sanabria set is currently available, but a sale is unlikely due to the large size (no matter its rarity). It seems the best alternative is to simply restore it, but I will need local electronic help and almost certainly another 27-inch tube.
I also have an assortment of radios as well as a beloved Rock-Ola Super Rocket that are getting attention in small increments. Hopefully there will be some advice and resources here.
Regards,
Gene
Old 01-15-2012, 09:20 PM
If it is a TV and the CRT tube is still under vacuum then there is a high likely hood that THE CRT is still good. If there is a TV service shop near by that has a CRT tester for older tubes they could probably test it for you.
Old 01-20-2012, 06:23 PM
hey I use to live in Woodyland Ga.......
Old 01-21-2012, 07:53 PM
JohnHacker1's Avatar
JohnHacker1 JohnHacker1 is offline
Welcome-and good luck with the projects!
