Old 02-06-2012, 07:30 PM
radio nut's Avatar
Born in the wrong decade
howard radio
I went to a flee market and found a howard radio that I'd like to buy. I'm not sure what model it is but it does have a tuning eye so it should be late 1930's. Its a table top and it is kind of rough but for ten dollars I am not too worried about that. I noticed when I look in the back that one of the speaker wires has been pulled out of the output transformer. Ok, I have gently peeled back the paper on one before ,found the wire and just soldered a new one on and was back in business.If this one is not that easy what kind of hoops will I have to jump through to find another one?
Old 02-06-2012, 07:55 PM
You MIGHT go down to Fair Radio there in Lima & see if they have anysuggestions...They just MIGHT have a substitute tranny that would work.
Old 02-06-2012, 08:04 PM
See if you can find a model number on it, so one of us can recommend a replacement that will work.
Old 02-06-2012, 08:19 PM
radio nut's Avatar
I will check again for the model number. The origiinal tag is there but it looks like someone spilled coffee or soda on it.
Old 02-06-2012, 08:21 PM
bob91343 bob91343 is offline
An output transformer is very easy to find. They are uncritical, and a generic unit will do just fine. Or you can cannibalize another set.
Old 02-07-2012, 11:23 AM
On a early 50's majestic TV that had a blown audio output Xfmr. I just replaced it with a similar sized unit that came from a amp from a cheap Deca HiFi phono console I junked, and it works just fine like that.
A generic replacement or a junked part should work fine.
Old 02-07-2012, 12:31 PM
[QUOTE=Electronic M;3026365]On a early 50's majestic TV that had a blown audio output Xfmr. I just replaced it with a similar sized unit that came from a amp from a cheap Deca HiFi phono console I junked, and it works just fine like that.
A cheap Decca! LMAO. Thats an Oxymoron. (sp)
Old 02-07-2012, 01:48 PM
radio nut's Avatar
I thought an output tranny was a little more of a specialty item. At Fair radio they have a box of the same size rca speakers with the trans. on them, so I will just grab one of those and mount it. Ok, I did not know it was that easy. Thanks. Oh, One more question if I may. because of price I have been subbing 5y3 rectifier tubes in my radios instead of 5u4 tubes. Is this a mistake?
It used a three tube amp for stereo, no tuner, dual volume knobs instead of volume and balance, puny speakers ,and an earlier version of the changer in that Arvin you were surprised I used to play records in a Goodwill. I have no clue what it originally sold for, but from scrapping it I got the feeling that it was cheaply made (I could lift it with one hand). This thing gave me the impression of a good sounding cheeply made table model's electronics stuck in a console for the heck of it.
Old 02-07-2012, 04:04 PM
The 5U4 is rated for somewhat more current than the 5Y3. So look up the tube to find the allowable current and compare it to the load in the set.
Of course, if you aren't a purist, a couple of 1N4007 diodes (for pennies each) and a resistor will substitute just fine in almost all cases.
Old 02-07-2012, 04:33 PM
...I have been subbing 5y3 rectifier tubes in my radios instead of 5u4 tubes. Is this a mistake?
Just curious, but what radio(s) do you have that use 5U4s? Being heavier duty with a 3 amp filament, they were more exclusive to TVs and large amplifiers. Whereas 5Y3 with its 2 amp filament was more commonly used in radios.
Old 02-07-2012, 05:37 PM
radio nut's Avatar
My capehart 21n2 uses 2- 5u4 tubes. I am using 5y3's in it now. I had a couple of old tv's I did the same thing with. I have'nt noticed any problems doing that but wanted to make sure.
Old 02-07-2012, 06:27 PM
Those 5Y3's are probably going to have a reduced service life doing the job of 5U4s.
Think I'd go the silicone diode route before straining a 5Y3.
Old 02-07-2012, 06:57 PM
Every Howard I've seen on Da Bay has the std BCB + a couple of SW bands....What does this 'un have ?!?
Old 02-07-2012, 08:03 PM
radio nut's Avatar
The same.... broadcast and sw. Its rough but I still like it. the metal dial has rust where the painted numbers used to be.the rest of the dial is clean and shiny. The cabinet is in one piece but needs a lot of tlc. I will post pics when I get home. I always liked a set with an eye tube. Kind of makes it stand out when running
