Old 04-12-2012, 06:06 PM
jbivy jbivy is offline
complete novice
Metrodyne 6 schematics needed
So I just picked this up on ebay for a good price, but i cant seem to find the schematics for this particular model. Or what batteries it ran off of.
This will be my earliest restoration and im very excited about it. This will be my first battery eliminator ive ever built. So any tips there would also be appreciated.
EDIT, oops. This is the "super six".
"Good morning whiskey, good morning night. The end of the world is in my sight." Hank 3
Old 04-12-2012, 07:13 PM
Nice score Did you see this ad on ebay ? http://www.ebay.com/itm/1927-METRODY...-/250451949684
Old 04-13-2012, 06:15 AM
Reece's Avatar
Reece Reece is offline
These things are pretty simple and don't have many components, maybe only two or three fixed caps and a grid leak. I'd be concerned about the green on those coils: were they supposed to be green or is that copper corrosion?
Edit: The schematics for early TRF's are all about the same. Things to check first with your ohmmeter are RF coil and audio transformer continuity, any loose or corroded connections. Sometimes only certain tubes are on the rheostat and the others run full on. I see from other pictures on the web that the coils were originally colored green so maybe only of cosmetic concern.
Reece
Old 04-13-2012, 07:39 AM
complete novice
Ive found several pictures of this chassis and yes, the coils are green from the factory. I found out it takes 45, 90 and 105 volts. So ill need to find out how to make a battery eliminator for it, for those. I assume i can just use three transformers that give out the approximate voltages?
But id still like to find a schematic for this, if one exists.
Old 04-13-2012, 08:04 AM
Reece's Avatar
Sent you a PM.
Reece
Old 04-25-2012, 09:14 PM
complete novice
Well it was packed badly. Apparently a bracket broke off one of the tuners, it slammed around the inside of it breaking the other tubes and chipping the other condenser.
So.. i guess ive a nice case with three coils and a variable resistor with a jack. Since the face plate is metal it can be unbolted easily. I figure since ive an old orphan westinghouse super heterodyne chassis laying around, ill put it inside there. Mount the knobs on a custom face plate. Ive some 1/8th inch zebra wood laying around that might look classy as the face plate. Maybe look up if there is anyway to modify that old wr-258 chassis for better performance.
