Old 05-09-2012, 06:22 PM
Magnavox300's Avatar
..better in black & white
Did I melt a resistor???
Working on my 1960 Magnavox set.
I finished installing the electrolytics, and had to wire in a resistor between two of them.
When I heated the wires with the soldering iron, the resistor started bubbling a little on the outside.
Did I do any damage to it internally? I was only at 15 watts.
Thanks for any help!
Magnavox300
Old 05-09-2012, 07:00 PM
DavGoodlin's Avatar
Motorola Minion
I bet you're OK . Those carbon resistors are pretty tough. Just be careful with transistors, diodes/rectifiers when soldering.
Old 05-09-2012, 07:17 PM
Thanks Dave!!!!
Old 05-11-2012, 03:07 PM
6GH8cowboy 6GH8cowboy is offline
Soldering
Sometimes a low wattage iron can take additional time to heat the joint and that lower heat coupled with the added time can cook parts. In such a case it is better to use a slightly hotter iron to get in and out quickly so the heat has less time to "travel". Just food for thought.
Old 05-11-2012, 03:48 PM
I can be a worry wart sometimes and test heated looking stuff or things that I may have damaged. Only takes two seconds to hookup an ohm meeter to a resistor and make sure....
Old 05-11-2012, 08:26 PM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
How about an aligator clip on the lead to draw some of the heat?
Old 05-11-2012, 10:29 PM
Einar72's Avatar
Einar72 Einar72 is offline
Chasin roundies since '79
Maybe there was some stuff on the outside of the resistor? Waxy buildup?
Old 05-11-2012, 10:48 PM
mstaton's Avatar
mstaton mstaton is offline
"Book em Dano!"
You would of melted the wires before that resistor. I agree with Einar, probably some kind of wax or something similar. I've seen stuff like that before. Not an issue.
Old 05-20-2012, 09:36 PM
Tubejunke's Avatar
I have seen many 1 watt or larger carbon resistors in circuit and working fine with bubbling evidence which I would think is a normal part of their heat dissipation process. Some of what I have seen could have been in a circuit where a capacitor had at some point shorted or leaky and the problem was fixed before the resistors were damaged. I think they are pretty much OK up to the point of smoking out.
