Old 06-02-2012, 08:15 PM
mjennens's Avatar
mjennens mjennens is offline
Old Guys Rule!!!
Calibrating an LG PA5500
Can anyone point me in the direction of a how-to for calibrating a plasma TV? I just purchased an LG PA5500 and would like to calibrate it. I was told that BestBuy will do it for a fee, but it's not difficult so a guy can do it himself. I like the picture as it is, but tweaking and fine tuning is always fun!
Thanks,
Mike
Main
Receiver Pioneer SX950 Speakers ADS L690 Source Dell Inspiron E1505
Other
Receiver Sony STR5800, Sony ST6036, Pioneer SX1010, Marantz 2235B
Speakers 127 Fonkens, Dayton BR1, JBL L40, Klipsch KG3, TB 3CR-Ti
Projects HK330A, Packard Bell Tube Set, RS1354
Old 06-02-2012, 09:02 PM
Professional calibration involves an expensive colorimeter or spectrometer and software. If you like it the way it is, it's best to leave it alone, IMO. IF they don't do it with the high end gear, it's not worth the money. You can do the simple black level, color saturation, and hue settings with a test pattern, and you can pick color temperature from whatever choices they give you, but when it comes to setting gray scale tracking, and gamma, you need the gear.
But I know, you really want to try playing with it. So start with the customer controls mentioned above, and then think about whether you want to get more complicated.
Calibrating a computer monitor is easier because the adjustments can be made either in the video card if necessary (most common) or in the monitor itself, if its hardware allows it, and the software is supplied with medium-expensive gear to work with a Windows or Apple machine. For a TV set, you must get into the service menus and firmware, which are different for every brand and often for different models of the same brand.
